I recently bought a H23 intake manifold on ebay and the throttle body was not included. Will my F22 throttle body fit on this? I doubt it will because The FITV is under the throttle body on a H23 if I'm not mistaken. What would be the best throttle body for me to get? Just a H22 or H23 throttle body? Also, my car is a auto and the F22 throttle body has a spot that the tranny cable goes on. Will I have to get a throttle body specifically for a auto or does the manual throttle bodies also have the cable the same way?
Best throttle body for a H23 intake manifold
You'll want to get an auto throttle body, though you can probably just swap rotors.
H22 and H23 are the only ones that will work. There are performance options, but unless you have the other mods needed, there's no point in spending the money. They're usually upwards of $300. You could always send a stock one to Maxbore and have it modified for about $100.
I believe the S2000 throttle body can be used as well. Again, unless you have the mods to support a larger throttle body, it won't do much.
Originally posted by musteredonme View Posthow much bigger is the H23/H22 TB over the stock F22??
F22A1 and F22A6: 57mm-58mm
H22/H23: 62mm-63mm
true but that means cutting slots in the rivet/screws, not a big deal but just a heads up to the guy so he doesn't have to waste his time, he can just choose to do it like the rest of us
