white exhaust smoke after spark plug install
    is this normal? my first time changing plugs, installed NGK V-Power's, gapped them, only tightened them to snug, etc. but get smoke when started and when i rev the engine. help please!
    Members Ride Thread: http://www.cb7tuner.com/vbb/showthread.php?t=126992
    If the old spark plugs had oil on them it probably dripped down into the cylinders... If thats the case, your spark plug tube seals are leaking. They come in the valve cover gasket kit.
    Finally Up and Running. Numbers to Follow. Check my MR
      yup prolly not too big of a deal...i would drive it for a day or two, and see if it clears up, which it prolly should..also check ur plug wires to make sure there is no oil getting in there from the tube seals like 406 said..
      Lost Motion Inc. Repair and Performance Automotive
        awesome thanks guys. just didn't want to do anything harmful to my engine, obviously I don't know much haha. I had figured I got oil somewhere since the old plugs were drenched.
          Yep tube seals are goners the time the plugs were out oil was draining down on top of your pistons till the tubes were empty so then when you fired it up all that oil is burnt and hence a cloud of white smoke no harm in the cloud but you better replace the tube seals soon, it wont get any better.
            The last time I checked, oil smoke was blue, white means water in the combustion process somehow. If this doesn't clear up within ten minutes (it shouldn't take long to burn off any oil that leaked into the cylinders), and it is white smoke, I'd get it to someone who knows cars and have it looked at.
              If it's just a small amount of smoke, it may look white regardless... Oil on the plugs means leaking tube seals for sure, so fix that. $40 for a valve cover gasket set isn't much.
              If you're really blowing white, then it's likely that you're burning coolant. The head gasket is the most common thing in that case... that's not fun.
                yeah deever is right, i had teh same thing happen replaced teh valve cover and spark plug gaskets and p roblem went away.
