Not a CB7
    Not a CB7
    Ok, so my sister has a 98 EX Accord. 4 cyl.
    Both motor mounts were bad, and it shook like an old diesel when at idle.
    Both motor mounts replaced, and now its worse....any ideas?
    2000 Acura TL-P - Daily
    1993 Honda Accord SE - Sold
    1996 Infiniti J30 - Sold
    1997 Honda Civic EX - Sold
    1996 Saturn SL2 - Totalled
    1982 Mercedes-Benz 300SD - Sold
    1982 Mercedes-Benz 240D - Totalled
    Were they torqued properly?? I read somewhere that that can happen.
    1993 Accord EX
    2011 Subaru STi
      prolly not torqued properly...if they were then it prolly wasnt a mount problem to begin with..
      Lost Motion Inc. Repair and Performance Automotive
        ok so you found 2 broken mounts and replaced them?How long was it in that condition?
        so I'm thinking because it was shaking so much the other 2 mounts are not broken but were you insert the bolts it might be worn out!
        Start your car......pop the hood.....let it reach normal Temp........have someone go at the car.....engage the e-brake pop it in first gear and give it slight gas enough to make the rpm jump and see what the engine does.
        If its shifting back and forth try and take a look at how the mounts act....good mounts dont move from there place.....worn mounts will have play and will shift with the engine.
        I think if the mounts shift you can add a washer to help with the play!!
          Front and back, or left and right?
          Are you sure the engine is running right (not misfiring) and that the engine mounts are the cause of the problem?
          My 5.7 LS1 Holden Ute
            is it auto? if it is then just alternate going to reverse then drive. if it shakes real bad then it might be the front mount.
            also if the motor has been on bad mounts for a while and u just replace the side mounts then u might also look into replacine the front and rear.
            but of course it could also be that the mounts arent torqued to the proper specs.
            the options are endless in my opinion
              Front and rear mounts were replaced.
              It wasn't that. Something is hitting under the hood. Need to get it on a lift and give it a closer look.
