scratching in third...
    when it goes into 3rd 0ver about 2600 rpm, not alot of resistance but definately a scratch, i have a new stage 1 im trying to put in. lowest offer i got though was like 390...that normal? is there another way or is it possibly something else?
    1990 accord LX-Laurel Blue
    predator intake/OBX header,down pipe and resonator
    tune up-belts,gaskets,fluids
    17" rims and tires
    stage one clutch---man i got stop in read before i send...
    17" rims and tires
      Your gear syncros are wearing out.
      1993 Accord EX
      2011 Subaru STi
        is that just as bad as a fix? i dont have my manual on me right this sec. i got an idea of what it is, someone want to gimme the down low on that?
        17" rims and tires
          They can be replaced. IDK how though.
          1993 Accord EX
          2011 Subaru STi
            cool thanx for the info...if anyone knows please chime in....i need it done asap, its my only ride....
            17" rims and tires
              You would have to pull the tranny and open the case. The syncros ride on the main shaft between each gear set. Its what engages the gears when you shift. The shift forks sit in a slot in the middle of each syncro and when you shift gears it either pushes a syncro forward or back depending on what gear you are going into. I havent had a Honda tranny apart but have worked on many diesel tranny's, theyre huge but the operation in basically the same. Im thinking the honda tranny probably has three syncros and if third gear is grinding then its probably the middle one, you also need to inspect that gear to make sure its engagement teeth are also not worn.
              "Brought to you by Carls Jr."
                wow ok...that sounds serius, i think i get it though...its gonna cost some cash....anyone have a ballpark figure? if it alot idk maybe ill do a trany swap for a lil more....
                17" rims and tires
                  thanx agian doughnut, uve given me quite some knowlage the last week or so...
                  17" rims and tires
                    bump...tryin to figure this out=/
                    17" rims and tires
                      prolly lookin at about 1000 for a rebuild i would say...very expensive..unless u plan on keeping the car forever, its prolly not worth it..i would try to find a good used trans and do it that way....when u replace synchros u need to replace all bearings,seals, and anything else that is worn in the trans when it is dissasembled....as far as price for the clutch i do em for 260..so 390 is a little high...the labor rate must be higher....just to give u an idea..
                      Lost Motion Inc. Repair and Performance Automotive
                        holy shnikeis batman that a sh*t-ton of money, i love this car though...even though im broke,im not letting my cb7 go i find away...the a6 conversion is gonna have to wait then... so ok how bout a swap, if i buy the trani myself and have someone put it in would it be cheaper than bring it to them and charging me for the new trani? what about an h23, or f22b, is it a direct swap?(just the trani not full swap)
                        17" rims and tires
                          yeh more than likely way cheaper if u get it....u already have a clutch, i would do a rear main seal,and new flywheel or resurface the old one...proly lookin at 3 to 500 buck depending on where u go
                            your refering to labor after i buy the parts on ur estimated price?
                            17" rims and tires
                              could try some of that new manual tranny fluid...I hear it helps a lot with this issue. Won't fix it or solve it...but can reduce the crunch until you can fix it.
                              ____
