alignment?
    alignment?
    okay so, this may be a stupid question
    but, i was gonna go get an alignment for my car or whatever and i was told i should get one while i have stock wheels on my car...
    and then told by another person that i should get one wit the 18's bcuz if i get one wit the stocks and then put the 18's back on the alignment would go again
    i dont kno, which is the right thing to do?
    ***sorry if this is the wrong section
    put the wheels you're gonna use on, then go get an alignment.
    峠 で ドリフト を して 下さい。
    steam linky facebook, y0 俺 は 走り屋 です。 clickable ^
      Yea, that's what I plan on doing. I wanna get my car the exact height that I wanna keep and I'm gettin' 17's from my buddy, and THEN get an alignment, because during that alignment, they can also adjust the toe (if your wheels wear on the inside, because you're lowered), that way your wheels will be perfectly straight and adjusted to the wheels and height of the car.
      Get the alignment with the 18's if you plan on keeping them on the car.
      98' Mustang 3V Swap
      11' VW CC R36
        You don't have to switch unless you're bored lol.
        Just go in and get it aligned.
        1996 Honda Civic LX 2009-2012
        2012 Kia Optima LX 2012-2013
          It shouldn't matter if you have 18s or 15s. As long as your steering rack isn't messed up, like mine is. Your car will go straight. Mine's leaking so I'm thinking that might be affecting the alignment.
            Yes ....slap the 18s on and go get alignment!
            but accords only have toe adjusment! unless you have torsion bars or a camber kit!!
            Tell them to just adjust the toe......they might charge you less!
              keep the tires on your going to use. i have to get mine done as well replaced the rack and pinion when i did my new tranny and stage 3 clutch time saver.
              Marry Jane
                So long as the wheels are straight (not damaged) then it makes absolutely no difference what wheels are on the car when aligned.
                Regards from Oz,
                John.
