how do you bypass a neutral safety switch
    and start the car without the clutch. where do the wires need to go to? which wires? if you have info let me know. pics a plus. thanks
    Frost White CB7 Crew - Member #43
    H22 Motor fund:0.00
    umm y would u want to do that first of all??second of all a neutral safety switch is on automatic transmissions, but there shuld be a starter interlock switch on the clutch pedal bracket, but im not gonna tell you how to do it its very unsafe
    Lost Motion Inc. Repair and Performance Automotive
      Why is it unsafe? What would happen?
      H22 Motor fund:0.00
        turn the key in to start it in the morning and pending on where you leave the shifter... why would youl like to remove it? have you swaped something in?
        96 Accord SiR driveline installed. CF2 donar
          No swap. Its just that the pad on the clutch pedal at the top is gone and i cant get to it to replace it. How do i get to it? What do i need to do?
          H22 Motor fund:0.00
            i got a remote start on my manual car, my buddy that installed it did it, i will ask him how he did it, i guess its not safe if you leave it on gear(which i never do) ive had it for almost 5years, my fam and friends know about not leaving my car in gear if they ever drive the car too, but then again im the only one that drives it!
              very unsafe to bypass that switch
              no matter how anyone says that they will be very careful a mistake can happen.
              better safe than sorry
                Should be easy, look up under there on the clutch pedal and look for a switch that opens when the clutch pedal is pressed. just remove the switch by taking it off the bracket some how and just leave it in the open position all the time.
                or cut and tape one of the wires going to the switch.
                That should work. lol.
                  thanks for the warning guys but i got it thanks to some searching on google
                  H22 Motor fund:0.00
                    I couldn't find a way to get to it without pullin the whole pedal assembly. I replaced it with a door panel clip that pushed in snug. (> Just a plain rounded head. You can get them in packs at any parts store for cheap. The clutch switch is at the top of the pedal. The switch to the front is the one that cancels your cruise control when you press the clutch. You dont want to bypass it. If you start your car in reverse with a kid behind the car, you will hate yourself forever.
                    My inferiority complex isn't as good as yours.
                      Very true. When you start the car in gear it will lurch forward. Not fun when you go out in the morning to start the car and forget that you left it in gear. I did that ONCE since I did the auto-->manual swap. Scared the crap out of me since the car in front of me was a M3.
                      3 CB's gone....
                      1 WK Overland....
                      Still miss the CB though......maybe one day.
                        its ok i dont ever leave it in gear at all though
                        H22 Motor fund:0.00
