help!
    help!
    ok u guys may remember me from that ignition switch problem thing!
    well i went to the junkyard,i got one,put it on,my my rpm is still going crazy!
    i thought it was gonna b that,guess not,i replaced ignition module like 2 months ago almost 3.soo thats fresh!'
    any clues anybody!!!!!!!!!!!
    IT MAY BE AUTO BUT IT SURE RUNS FAST FOR A F22A6
    what are your RPMs doing again.
      they are flying everywhere
      once it gits 3k
      it just goes really bad
      like 3 to 6 then whne hitting gas hard it goes all the way to 6 maybe sometimes 8k
      like bouncing everywhere
      and it makes my car like not run goo at all like misfiring cause the car dont know what rpm its at!
        checked your plugs? tune up?
        any vaccum leaks?
        Ride: 2002 Lexus IS300
          naw the idle stays at 700 and yea
          tune up was never a problem
          i always do one
          i have new rotor new ignition module
          wat else can it be??
            smells, tastes, barks, looks like vacuum leaks or control Idle valve.
            Barrabas !!!
            Short ram intake, rasonator, muffler change and 4-2-1 exaust for $25 from the Junky, arospeed coilover springs and ex-jarhead gold 15th Anniversary rims. More mods to come soon !
              Igniter. Not ignition switch. Big difference. The igniter is in the distributor.
                how does it look the igniter looking thing????
                cause i know i replaced teh ignition module!!!
                it has like 3 connectors!!!
                how does it look!
                  Ok, same thing. That's what you replaced, apparently. Beige square with 3 flat male connections, with the 3 gel-covered plugs that go on it.
                  Have you checked your wiring? Battery cables, grounds, etc?
                  Does the car run poorly, or do the gauges just go nuts?
                    its the one in the middle of this picture. thats what the igniter looks like when you open up your distributor cap.
                    same thing happened to my car. it died on the freeway.
                    if you can find one in the junkyard from a civic that works too. thats where i got my replacement igniter.
                      hmm well i replaced that like not to long ago and stuff!!!!
                      hmm the rpm's go crazy and makes my car stutter alos
                      like it dont know what rpm its at!
