Help w/Bogging Issue...
    http://www.cb7tuner.com/vbb/showthre...t=cleaning+egr
      i fyou figur this out let me know i have had this same issue now for over 1 year have done all suggested changes even got a new motor and still doing this i have changed even the pgmfi sensor im at wits end god its frustrating.
      h23a3 lxinks
        check you trany ecu solenoid or TCU that does not want to shift to next gear and car start to bugg out, I know similar think happend to my friends car, just something new to look for
          i have a new tcu in this bitch the old one was bad and would get stuck in 2nd so i know thats not the issue but good suggestion
          h23a3 lxinks
            Well, I still haven't gotten this figured out and I'm starting to wonder if I just didn't do the seafoam thing the right way. The arrow in this picture IS pointing at the brake booster line before it goes into the intake manifold, right? This is where I seafoamed the thing.... Disconnect that line, pour 1/3 of a can in as the car's idling, let sit for 5-10 minutes, enjoy the show, right? Thanks.
              enjoy the show and oil change.
              maybe you have a clogged catalytic converter?
                dpmark,
                Did you ever solve your problem? Test your coil to see if its up to specs. Did you ever get that rotten eggs smell from the exhaust?
                1992 Accord Coupe 5-Speed
                  got a new relay when the car wouldnt start that fixed that and changed the fuel pump and mine still bogs at low rpms and city driving!!!
                    Mine feels like its running on 2 cylinders........but no CEL ?
                      HEY! havent read everyones posts, but it sounds like a clogged catalytic converter. My stepdads old accord had this same problem with bogging down so bad that he would have to floor it for the car to get going.
                      His car eventually caught on fire at 222,000 miles. check that out and let us know!
