ok before you guys start naming me everything in the book plus more, wat is the purpose of the button on the automatic shifter. it says normal and sport. like i said be easy wit me just a newbie. thanks
button on auto shifter
it just keeps you in gear for just a little bit longer...
93 Accord LX Sedan (sold)
Here is an interesting tidbit I always kept handy for explaining that little button.
Enjoy!
The Accord's 4-speed automatic transmission is a new design that's compact, smooth-shifting and efficient. It is computer controlled and has a driver-selectable Sport mode, lockup torque converter and seven shift positions: Park, Reverse, Neutral, D4 and D3 with Sport mode, Second and First (Low-Hold).
Unlike most conventional transmissions, it uses three parallel axis shafts-a main shaft, a counter shaft and an additional secondary shaft-instead of two shafts. The unit is barely larger than a normal transmission (it is just 2 mm longer than the 1989 two-shaft automatic) yet permits the use of a fifth clutch so the transmission can be held in low gear until the driver moves the shift lever. This "low-hold" feature is useful when low-speed power or engine braking is needed, as when pulling a boat trailer out of the water or descending very steep inclines.
To improve efficiency, the new transmission has a lockup torque converter that engages in second, third and fourth gear when maintaining steady speeds, and third and fourth to provide engine braking when decelerating.
For smoother shifts, the transmission ECU signals the engine ECU to retard the spark between shifts, momentarily lowering engine torque, so that gear-change shock is reduced. For smoothing the upshift from third to fourth, and downshifts from fourth to third or second, there's an accumulator control system in the shift valve that maintains steadier hydraulic pressure and makes the shifts less abrupt.
The driver-selectable Sport mode is designed for sporty performance at partial throttle levels. With the shift lever in the D3 position, pushing the Sport mode switch on the shifter directs the transmission to shift at higher rpm points when going from first to second and second to third. Using Sport mode in the D4 position extends the function to the third-to-fourth shift. The Sport mode increases responsiveness and is useful on long grades to keep the transmission from "hunting" for gear ratios.
yeah the lower the RPMs the less gas youll waste
Originally posted by maney77 View Posta higher shift point so longer gears
It just keeps the transmission from shifting as early.
Originally posted by ikayto View Postit says its only good for parital thorttle lol.
And yes, it's not good for fuel economy. It's actually a pretty worthless feature, which is why it only lasted for the 1st 2 years of the CB.
