car isnt getting fuel
    my buddy has a 91 coupe and he isnt getting fuel. i tried the main relay and swaped out my old ecu as well. now when we turn the ignition key to on on my cb you could feel the main relay engage. on his car it doesnt. were should we look next.
    92ex coupe h22
    93 240sx with silvia front end (kadet in the works)
    http://www.cb7tuner.com/vbb/showthre...=1#post1894990
    his main relay is NFG. was it used? replace it with a new one or you can try swapping it with yours but its proally not worth doing all that work.
    '93 EX-R 5spd
      Did you use your working relay in your buddy's car? That isn't very clear... if so, then there is another problem. Check/clean all battery connections and grounds... go from there.
        Can you hear the fuel pump making noise?
        PARTING OUT MY 1990 EX COUPE!! EVERYTHING FOR SALE! CLICK HERE
        Listen or download the first 4 songs I completed for my new upcoming album here!!
        My member's ride
          check the connection that plugs into the main relay to meke sure you are getting from all of the teeths of that plug, they should sale the haynes manual for our cars at your local parts store, i recommend picking up a copy, also check your fuel filter it may be clogged if all that fails check your fuel lines, and also check the fuel pump itself, have your frind put his ear next to the fuel tank, the pump should make some noise when you put the keys in the on position,
            Check all connections to the relay or switch out the relay.
