needle reading hot but dont see signs of overheat
    recently my car has been saying its overheating but i dont see any sign of coolant leak smoke coming from engine only thing i noticed is that the coolant fan is not coming on if i take out the fuse and put it back in the coolant fan comes on and then turns off is my fan shorted out or do i have an electrical problem , and i also noticed that a.c fan stays on as soon as i turn on the car someone help thanks
    BK ALL DAY
    i had the same prob . turned out the be a bad fan relay(in underhood fuse box) and timer relay(in driverside of dash). your kind of kick starting it when you pull the fuse and put it back in. i'd check/change the underhood relay first.
      it could be your sensor for the guage and the fan switch.
        thanks for the help im going to look into that and replace the relays and see what happends
        BK ALL DAY
          I replaced the fan switch, on the header, and that still didnt help.
          Originally posted by Jarrett
