i have replaced the master cylinder and 3 calipers im lost can someone help cause it gets worse when the car is hot but when i first start in the morning the pedal is kinda stiff help help help please
brake pedal goes to the floor when braking
If the system has been bled properly and the pedal still goes to the floor, then your master cylinder is probably no good. It happens, especially with cheaper aftermarket parts... though it can happen with brand new Honda units as well.
The only real way to test it is to have a different shop bleed the system... make sure that it's not an error on the side of your shop. Otherwise, assume that your new part came busted, and try to get a replacement for it.
If the shop didn't bench bleed the master cylinder, that makes it an absolute PAIN to bleed the rest of the system properly.Originally posted by sweet91accordif aredy time i need to put something in cb7tuner. you guy need to me a smart ass about and bust on my spelling,gramar and shit like that in so sorry.
