noob question, PCV VALVE
    Ok so I'm still replacing ORIGINAL parts on my 1990 that I got from a little ol lady.
    Next on the list, PCV, how do I know if its bad? What would some problems that it would cause IF it is bad? Would it increase gas mileage if I changed it?
    I know its the original one and the car has 229K on it, lol.
    Just trying to get up to date on maintence on this car. Help me out guys.
    Also how do I replace it? I know where it is, but it looks like its attached pretty good.
    90 accord EX automatic F22A4 232,500
    DIY ram intake
    0gauge/4gauge BIG 3
    stock alt rewound to 120amps
    optima orange top 830cca 1030ca
    fully synthetic valvoline "Max Life" 5w30
    Other rides:
    2004 Jeep Liberty v6
    2001 Honda civic ex coupe 1.7 vtec
    Take it off and shake it. If it rattles, it is fine. If you are sure its original, you should replace it anyways. It's a $10 part. Probably less.
    Probably won't affect mileage any, but it will contribute to the overall health of the engine in the long run. Won't cause any big problems, per se, but it could cause a dangerous condition on a high mileage car like yours with lots of blow by.
    1992 Prelude S w/swapped H22A
      yea, id recommend replacing it anyways. 5 dollar part from autozone.
      if they stay closed, it wont allow crank case pressure to vent and will blow oil out your seals.
      if it stays open, you'll have problems at low end or the car will like to die.
        ive been thinking of replacing mine too. i think mine is bad, it had vaccuum but didnt rattle.
        would you suggest oem or one from autozone or kragen or something. if so, any brand i should shoot for or just whatever they have?
        91 ex sedan
        And now, new for 2012, a 93 ex wagon!
        Paypal verified
        Bought from: frootloops, 90accords, Agol
        sold to: Agol
          cheapest one possible, it isnt a rocket science piece. just check it every 30k miles.
            ok, and just squeeze the clamp, pull old one out, and put new one int and let go of clamp? sound about right?
            <--- newb still
            91 ex sedan
            Paypal verified
            sold to: Agol
              welll, i have a 90, and im pretty sure the f22 in it is not its original, all though it might be, i have a valve seal leak, burning minimal oil,moror has about roughly 120k on it, and, i want to know if the pcv could be attributing to my oil leak. ?
                Response
                If your motor seems to be burning oil, its NOT the PCV. The PCV just sucks vapour from the valve cover into the intake plenum so the valve cover doesn't get pressurized.
                I installed an inline fuel filter in that hose and wow did I see alot of nasty build up that I dont want going back into my intake. I'm installing a oil catch can tomorrow.
                To find out how bad your oil burning is, take it to a shop and watch them do a compression test and show you the numbers. Then you can get an idea of the variance of the cylinders pressure.
                Sorry, but I don't know what the cylinder PSI SHOULD be for our motors...maybe someone can post it....
                  175...i have a brand new motor and mine are 175 across with 4% leak down.
                  PCV's are so cheap i dont even check them but just throw the old one away and replace. it's kinda like oil filters, would you reuse one that only has 300 miles on it?
                    Hey
                    Seeing as PCV is suppose to mean Positive Crankcase Ventilation...and ours is on the valve cover... can we call it a PVCV ?...lol
                      $2 & something cents
                      93 Accord LX Sedan (sold)
                        wow, that cheap? where at?
                        91 ex sedan
                        Paypal verified
                        sold to: Agol
                          I replaced mine Saturday. I picked up a fram pcv valve from wal-mart for $3.49
                          1990 LX Coupe-----1992 LX Sedan
                            i didnt even know wal-mart carried those. where was it? aside from the auto dept. by the air filters or what?
                            91 ex sedan
                            Paypal verified
                            sold to: Agol
                              yep, it's in the same area as the air filters
