I'll put this in the beginner section too...
Lots of questions...I'm putting them in "quote" form to make it easier...
Here's the story.
ok I'm going to wait on the super cup kit (neuspeed koni yellows (springs/shocks))...but I need new ball joints and an alignment NOW...too much negative camber eating my inner tires.
I'm guessing my springs are sagging a little, but I'm sure the ball joints aren't helping.
I am looking into ball joints right now, and I've decided to not replace the whole upper control arm. I will replace just the ball joint, as i have found several "upper ball joint" only parts.
And...if that's the case,
G-man informs me that neuspeeds koni yellows setup will give me a pretty good drop...
Here's the story.
Question 1
So, should I buy an adjustable ball joint to go in the upper control arm (front) or should I get a regular ball joint for the front? Then, once I DO get the new shocks/springs, buy an ingalls camber adjusting kit?
Question 2
What is your experience with the adjustable ball joints vs ingalls style camber correction kit (control arm anchor bolt style)
Question 3
Also, for the rears, is it possible to replace JUST the ball joints or do the only sell the whole arm.
question 4
won't I need something to adjust the rear camber as well once I buy this setup?
Question 5
So when I do get the koni's, will I need 1.5 degree +- camber correcting parts or a 3 degree?
