CEL's after a high speed blast
    last night i took my sister for a ride in the CB.
    after a couple 80+ mph blasts my car died.
    waited a minute and started her up again no problem.
    driving home from work today i got some intermittent cut outs of the engine.
    the engine lite flashed momentarily every time the car cut out.
    got it home, ran the codes.
    20: electronic load detector.
    where is this sensor/how do i repair the problem?
    i have a feeling this is the one causing me trouble.
    36: what i have found seems to be a traction control issue.
    my car doesnt have TC obviously.
    should i just ignore this one?
    The only TC I can think of would be Torque Converter.
    According to http://www.cb7tuner.com/vbb/showpost...83&postcount=2 , there is no code 36 hmm
    And the ELD is part of the underhood fusebox, its the little connector with three wires and runs to the altenator. Might just be the wires running to it, too.
    Opal Metallic Green '92 LX 2dr manual, 181k miles, '94 prelude VTEC wheels for summer (steelies with snow tires for winter), Omni-power struts/springs, and other junk
      sorry
      TC was spossed to be traction control.
      i'll check the second code again to make sure.
      by in the fusebox do you mean there is an ELD fuse?
      thanx
        Originally posted by H22artman View Post
        sorry
        thanx
        Do your research.
        http://www.cb7tuner.com/vbb/showthre...&highlight=Ecu
        Originally posted by aero View Post
        1 O2A - Oxygen sensor #1
        2 O2B - Oxygen sensor #2
        3 MAP - manifold absolute pressure sensor
        4 CKP - crank position sensor
        5 MAP - manifold absolute pressure sensor
        6 ECT - water temperature sensor
        7 TPS - throttle position sensor
        8 TDC - top dead centre sensor
        9 CYP - cylinder sensor
        10 IAT - intake air temperature sensor
        12 EGR - exhaust gas recirculation lift valve
        13 BARO - atmospheric pressure sensor
        14 IAC (EACV) - idle air control valve
        15 Ignition output signal
        16 Fuel injectors
        17 VSS - speed sensor
        19 Automatic transmission lockup control valve
        20 Electrical load detector
        21 VTEC spool solenoid valve
        22 VTEC pressure valve
        23 Knock sensor
        30 Automatic transmission A signal
        31 Automatic transmission B signal
        36 traction control found on JDM ecu's
        41 Primary oxygen sensor heater
        43 Fuel supply system
        45 Fuel system too rich or lean
        48 LAF - lean air fuel sensor
        54 CKF - crank fluctuation sensor
        58 TDC sensor #2
        61 Primary oxygen sensor
        63 Secondary oxygen sensor
        65 Secondary oxygen sensor heater
        71 random misfire cylinder 1
        72 random misfire cylinder 2
        73 random misfire cylinder 3
        74 random misfire cylinder 4
        80 Exhaust Gas Recirculation insufficient flow detected
        86 ECT Sensor (Engine Coolant Temperature) circuit range / performance problem
        90 Evaporative Emission Control System leak detected in the fuel tank area
        91 Fuel Tank Pressure Sensor low input
        92 Evaporative Emission Control System insufficient purge flow
        Resetting ECU
        1. Disconnect Negative battery terminal (never only take off the positive, cuz it can kill the battery when it grounds all the power out, if left for a while)
        2. Look in the Underhood fuse box, find the "Hazard" Fuse. Pull it out.
        3. Let the car sit for 10-15 minutes
        4. Reattach neg battery terminal and put fuse back in
        5. Restart car w/nothing on (radio, lights, a/c) and just let it run for a few minutes.
        6. Turn off, and then it should be good to go.
        Cali.Dumps.Harder.
          lol the problems started happening after he sold you the car.
            Ah, thank you FuncOvrForm. That's a more comprehensive than the info I found.
            The ELD is a small electronic module that's part of the fuse box, it has the small connector with three wires. I've always heard you gotta replace the whole fuse box, so maybe you'll luck out and its just one of the wires that's giving you trouble. Can't find a pic of it.
              thanks otto.
              thats what i was looking for.
              let you guys know what i find out.
                the problems actually started after i ressurected this bitch.
                that thing had much bigger problems last time Func had it.
                it was running great till just the other day.
                  Originally posted by FuncOvrForm View Post
                  i did the research B.
                  i didnt ask WHAT the codes were.
                  i was asking how to fix them.
                  amazing how the guy i bought the car from has the least amount of input on his old car.
                    Did you end up sorting/finding out what the problems were?
                    Btw why resurect a nearly 2 month old thread to bash FuncOvrForm?
                    My 5.7 LS1 Holden Ute
                      not trying to bash the guy at all.
                      he did great things for my car.
                      he even saved my hand from being shattered by installing hood spacers.
                      i just came back across this thread just now and noticed how lame his attempt was to answer my ? much less help his old car out. thats all.
                      no big deal in my eyes. i didnt even notice that post until now.
                      i figured out what was up with the car. took me about five minutes to fix.
                      never better. she runs great now.
