since the jdm has a higher compression then the usdm i need to know wats the best sparks plugs to use to unleash the beast out my h22a
Spark Plugs for h22a jdm
Originally posted by 1sickcb7 View Postsince the jdm has a higher compression then the usdm i need to know wats the best sparks plugs to use to unleash the beast out my h22a
dont use anything platinum.
platinum plugs require a tiny bit more voltage to fire.
while they perform just fine it could cause premature failure in a number of ignition parts.
iridiums have less resistance than platinum, therefore they perform just as well as the stock type plug but last WAYYY longer.
you wont find a plug that provides any noticeable increase in power over stock.
you may notice a difference but usually its due to an old worn out plug being replaced by a nice fresh one.
H22A SICKNESS!
