on a 93 accord ex 3 doors? I live in San Francisco
what is the correct tire pressure
in auto shop in highschool he told us to inflate 2 pounds over, but I've heard 8 million thingsMembers Ride Thread: http://www.cb7tuner.com/vbb/showthread.php?t=126992
my wagon...
front=32
rear=34
rear with weight=32
thats what honda says I should put. so I do
93 Accord LX Sedan (sold)
good rule of thumb, for stock tires, 32-35psi. For low profile 16s, 17s, 18s go at least 35psi. I normally run my 17s at 40psi on the highway if I'm going on a road trip. But if i'm just cruising in town at home, I go 35psi. Anything above 40 starts to prematurely wear out the tire in the center, and you'd be getting less treadwear out of them...which would cost you more money in the longrun. Oh yeah and check your tires at LEAST once a month. Tires can lose anywhere from 4-7 lbs of air depending on how long the car sits for at a time. Also, if you've got Dill valvestems...we've been having a lot of problems w/ them failing, so if you do, have them checked out for any defects. We've switched to Schrader Valves now b/c of those failing.
P.S. I work at Discount Tire Co.Last edited by Losiracer2; 08-27-2008, 12:57 AM.
the standard "overall" average passenger car pressure is 32lbs.
this is not a stated fact anywhere except for cars that actually post this on their production sticker.
it is a good pressure for about 90 percent of road cars (and most of our CB's) but not accurate for special (and increasingly more common) tire/wheel setups.
