High Idle after short ram install, help?
    Originally posted by blazen_accord View Post
    900rpms is NOT normal idle around 650rpm is. Have you try to re-adjust your Idle back down to around 650rpm?. on my car right now if I adjust my idle screw ablove 800rpm my idle will surge 700rpm-1500rpm non stop when i'm at partk or neutral. If I lower it down to 650rpm then the problem go away. If you follow the correct method to reset your idle rpm and that did not fix your issue then I hope other member can fix your issue since i'm out of idea.
    1. unplug the Fast Idle Air valve electric plug connector on the middle of the manifold.
    2. adjust the idle screw with no accessory/radio/light on to 650rpm.
    3. turn off the engine and remove the ecu and radio backup fuses (wait 1-2min) then install the fuses
    4. reconnect the Fast Idle Air Valve electrical plug and start your engine. Your Idle should be around 650 rpm in neutral of 5 speed or park if auto.
    GL
    thanks, I haven't done it yet, but I'm sure that will do it, I had to travel so I could check this thread.
    I'll let you know how it turns out!
    Colombian CB7
    http://www.cb7tuner.com/vbb/showthre...3A+1992+accord
      Well I give up, gonna take it to my mechanic but the guy is going to fix other thimg, I mean, fix the problem moding other thing ahgggggggggggg, never thought it would turn out this way witha SRI, so imagine the rest of the mods aaaaaaaghhhhhhhhhhhhhhhhhh so fck'n angry!!
      Colombian CB7
        Thanks everybody for the help, all the things that you posted helped me to lower it to 1400, finally, I got the problem , well not me the mechanic, IT WAS THE FUCK'N INTAKE GASKET, it was sucking by the mani and the gasket was totally burned, I'm an idiot, I know, but got my problem solved, I hope this help other people wiyh similar problems.
        Just put some oil where the gasket is seen and it shouldn't make any noises or suck the oil, mine sucked the oil and then burned it producing some withe smoke, that's the way you test it.
        later and thanks again!
        Colombian CB7
