Ok so if i buy an sri on ebay , there are good chances that my rpm keeps the same as it is now and i'll maybie feel more power ?
High Idle after short ram install, help?
that air boost hose is not plugged...goes into intake.
Forget about your idle before the install...just go ahead and recheck/reset your idle screw.
Reset your ecu.
If you can't get the idle to lower, then you've got a vacuum leak...if you bottom the idle screw out to get the idle lower (AFTER warmup) then you've got a vacuum leak.
you didn't unplug the vacuum line going to your fuel press. regulator did you? makes it dump fuel like you were WOT even at idle.
It is possible your o2 sensor is bad, makes a waste of gas as well...but I would not worry about that until you've ruled out everything else.
Why do you not have the line from the charcoal canister hooked up?
Advice...when you've changed something on your car and it worked before...but now it doesn't...UNDO what you did...go back to FULL stock (well as much as is reasonable) then, piece by piece redo the mod...that means...have ALL the vacuum lines where they were as stock...then...line by line...change it back to "modded".
if you touched it and it messed up...it's cause you touched it...so untouch it
Of course it could also be parts...but not in this case since this is just a tube to tube replacementLast edited by bcjammerx; 08-28-2008, 12:57 PM.____
Originally posted by bcjammerx View Postthat air boost hose is not plugged...goes into intake.
Reset your ecu.
Thanks, I'm gonna spend some time doing what you said, but I think I did this(you didn't unplug the vacuum line going to your fuel press. regulator did you? makes it dump fuel like you were WOT even at idle.), guess that's one of the problems, I'm gonna undo everything and go step by step as you said, but how do I fix it? i mean taht vacuum line that goes to the fuel regulator I unplugged and plugged again!
soo when u remove the stock air box u have to cap the 3rd vacumm line onto the throttle body???
i have it stilll there,
i took of my box everything off!
never capped it em i suppose to ???
i just left it there never touched it!
haha
dont feel anything wrong!IT MAY BE AUTO BUT IT SURE RUNS FAST FOR A F22A6
well the reason i was asking about that capped off line is because I don't see any reason NOT to have every vacuum line that WAS hooked up before a short ram or other intake setup still hooked up after the setup.
Deff. hook that fuel press. reg. back up, you'll be dumping WOT fuel at idle...no funs____
Originally posted by Isdoyra View PostDanm, from 100 people with SRI, I had to get the trouble one, hahahaha.
I'm gonna try to unplug it tomorrow and let it open, I guess it should sit to the normal 900rpms:
I let you know tomorrow, how it turned out!!
1. unplug the Fast Idle Air valve electric plug connector on the middle of the manifold.
2. adjust the idle screw with no accessory/radio/light on to 650rpm.
3. turn off the engine and remove the ecu and radio backup fuses (wait 1-2min) then install the fuses
4. reconnect the Fast Idle Air Valve electrical plug and start your engine. Your Idle should be around 650 rpm in neutral of 5 speed or park if auto.
GL90 Accord Coupe LX, Stock JDM H22A Engine 10.6:1 - Stock Automatic LSD MPA1 Trans, JDM P13 Auto ECU + JDM P19 TCU. Tune with Greddy E-Manage Ultimate
< 317WHP/227WTQ@11psi> B/W S256 turbo, Daily Driving on 93 pump gas - since 2006. Driving Turbocharged CB7 Accord since 2002.
i looked at my SRI intake setup. i have the vacuum hose from the air booster hooked up to my intake and it works fine. when i start it goes up to 1500 then goes down to about 800 when it warms up(it was that high when i got the car). so are you sure its the intake? its possibly something else
