92 LX Bogs out when given throttle... help plz.
    it'll turn over, idle for about 10 seconds, then, bog out. as if it's been given "anti throttle"... the rpm's drop when i give it gas. it's clearly getting plenty of fuel as evident by the smell of gas... therefore... with the way it sounds when it bogs out i'm thinking it's running super rich for some reason? i'll give a run through of my vac lines and intake tube and get back to you, but some advice would be appreciated!
    thanks,
    dan
    Check your fuel filter and make sure it isn't clogged. If it is, replace it.
    In fact, if your car has a lot of miles and you don't know whether it has had a fuel filter change before, I'd do it anyhow. After checking vacuum lines, that is what I would do.
    -orangeaccord
    GO BIG ORANGE!!!
    h22a swap/f22 tranny, 2.5" Magnaflow cat-back (well, the cat is gone now >_>), p/s delete... new stuff all around...
