H22 issue.. Knock sensor keep coming on... :(
    I've done a lot of research before posting here but I couldn't find anything very helpfull... I'm having trouble with my knock sensor on my H22... Last month my check engine (code 23) came on cause my gaz tank was leaking and my fuel filter was full on sh*t... I changed the whole tank, the filter and I cleaned the gaz line... Now that it's done I often have a CEL (code 23) wich is knock sensor and I can't find what could make this happen... The weird part is that this trouble is intermittent... It always happen when I'm on the highway (60mph +) and often when I'm cruising around in the city...
    I have some ideas of what it could be but before I want to know if somebody already had this kind of trouble and if yes, how did you fix that...
    Thanks a lot!
    did you change the knock sensor? my sensor was cracked so i had to get a new one
      No I didn't changed it... I know that could fix the problem... I just wanted to get some advice since the code keep coming on even if I changed the gaz tank and everything...
      thanks for the tip!
        get hondata and delete the knock sensor.
        member ride thread
        DIVULGE MOTORSPORTS
          Get a chipped ECU and tell company that you're getting it from to delete the knock sensor. Hondata is not cheap
            The knock sensor is there to protect your engine... Deleting it isn't always a great option.
            The first thing I would do is inspect the sensor, and make sure it's in good shape. If it's clearly damaged, then replace it. That should fix it. If it's not clearly damaged, then it may or may not be faulty... again, replacing it is one way to rule that out. Check your wiring as well... it's possible that the sensor is fine, but the wires got damaged somehow. Doing a swap can pinch and pull wires that shouldn't be pinched and pulled... I have a few like that (my oil pressure sensor wire is currently duct taped together... )
              do what dev say and make sure your knock wiring is shielded cable and the connection at both end (knock plug, ECU pin) is tight. My issue before was the ecu pin wire keep coming loose. Oh and make sure yo have the wire to the right ECU pin too.
              90 Accord Coupe LX, Stock JDM H22A Engine 10.6:1 - Stock Automatic LSD MPA1 Trans, JDM P13 Auto ECU + JDM P19 TCU. Tune with Greddy E-Manage Ultimate
              < 317WHP/227WTQ@11psi> B/W S256 turbo, Daily Driving on 93 pump gas - since 2006. Driving Turbocharged CB7 Accord since 2002.
