Someone may have already asked/answered this question but anyways what do you guys think are the best struts to put on our cb's once they're lowered? I put my coilovers on over a year ago and ever since my ride was lowered I've been riding on blown shocks, awesome! Not really, but anyways I've looked all over and have pretty much decided on Tokico Blues, what do you guys think?
struts?
struts?
Still hustlin that Old Skool.......it never ends.
vv My Member's Ride Thread vv
http://www.cb7tuner.com/vbb/showthread.php?t=123371Tags: None
Tokico Blues are stock replacement. They work for some, they blow for others. Overall, they're a cheap, non-performance alternative.
Koni Yellows are the best struts for our cars. Lifetime replacement warranty, great adjustability, comfortable when you want them to be, sporty when you want them to be.
Also, the quality of your springs come into play as well. Since you have coilover sleeves, I doubt you have anything worth riding on. There are only 2 decent brands... Ground Control and Skunk2... and I still wouldn't touch either.
I hear ya about the coilovers, although I actually like mine. I had originally planned on just putting lowering springs on but wasn't sure if I was going to get the ride height that I was looking for. What do you guys think about the Illuminas? I just don't want to blow another set of shocks after I replace the ones that I have on now.Still hustlin that Old Skool.......it never ends.
SensaTracs are the worst dampers I've ever bought (years ago for a horrid Mitsubishi). They are touted as being soft ("for comfort") at / near the static ride height, but stiffer above and below this, so as the suspension moves up or down it starts off soft then gets stiffer ("for improved handling"...).
Monroe achieves this not with any clever valving, but by machining vertical grooves in the damper wall so that fluid can bleed (read 'leak') past the seals and valves. These grooves are located at the position where the piston sits at static height, but peter out above and below this position.
The reality of this is that the dampers are in effect 'pre-worn out' at / near static ride height, which is very bad for handling response. For 'performance' driving', SensaTracs are even worse than the soft OE units.Regards from Oz,
John.
Originally posted by johnl View PostSensaTracs are the worst dampers I've ever bought (years ago for a horrid Mitsubishi). They are touted as being soft ("for comfort") at / near the static ride height, but stiffer above and below this, so as the suspension moves up or down it starts off soft then gets stiffer ("for improved handling"...).
i coulddn,'t argue with the price
free from my old job, inventory error
Even new junk struts are better than old blown ones... but yeah, getting a quality brand is important.
Illuminas are decent. Not the best, but not bad. Stay away from KYB AGX if you're going lower than 1.5". The warranty is void after that, and the ride is pretty lousy. I've had 3 different types: stock, KYB AGX, and Koni Yellows. Koni is the best by far. My Konis are tired, and I got them used... and they're STILL the best.
Right on, I appreciate the info. I've done quite a bit of research and really believe that the Skunk2's would probably be the best overall but I don't have alot of $ to play with. I was also considering pulling my coilovers off and throwing some Eibach's on instead, haven't quite decided yet though. Where is a good place to get the Koni's for a decent price?Still hustlin that Old Skool.......it never ends.
Originally posted by sideswipe View PostI was also considering pulling my coilovers off and throwing some Eibach's on instead, haven't quite decided yet though.Regards from Oz,
John.
Originally posted by johnl View PostThe only time it might be a good idea to fit lesser dampers than Koni, is to tide you over while the Konis are being reconditioned...
Konis are some of the best you can get for the CB Accord, without getting custom stuff from better companies. With a lifetime warranty, they're a fantastic purchase (though you DO have to return them to have them repaired or replaced...)
KYB, Tokico, Tein, and a few other well-known brands are decent, and will hold up to a drop MUCH better than 18 year old tubes that are already mostly dead.
I guess to change the question a little, I'm seriously tight on cash right now and need new struts that will handle my lowered stance without blowing again like the stocks did but also be cost effective, so what would the consensus be on the best choice? Besides the fact that I hate having to back down from a challenge just because certain roads around here will make my ride bounce like a basketball!Still hustlin that Old Skool.......it never ends.
I'm riding on GC coilovers w/ KYB AGXs, I love them, never had an issue at all w/ them. 4 way adjustable for soft/firmness in front and 8 way adjustable for rear. I'm lowered about 2 inches and have been sitting like this, w/ this setup for about 3 yrs now.
