what would be better
    The H22 transmissions are the same as the F22 transmissions in terms of strength and how they shift. The gearing is just different. It's best to have the transmission matched for the motor.
    It's risky boosting a stock H22, and building it up is very expensive. You can get away with more when you boost an F22, and they're cheaper to replace when they blow. Building an F22 costs about the same as building an H22.
    Read through the performance section of this forum. We have 5 years of info just begging to be read!
      How would it be a bad idea using an H22 with an F22A1? Just curious because this is a topic that I need some intelligent insight on...
        Well, H22 and F22A1 are both engines... I'm assuming that you're referring to the H22 with the F22 transmission (which has its own code... I don't bother with those because not many people know what's what...)
        The transmission on the F22 has longer gearing, which means initial acceleration will take longer with the H22. Once you hit VTEC around 5000rpm, you have another 2200rpm or so to rev before you have to shift. With the F22 transmission, you'll shift below 5000, and therefore shift out of VTEC.
          only gear i ever fall out of vtec is between 1 and 2... i shift at 7200rpm from 2nd to 3rd and it stays in vtec....i like the longer gears... i think it saved me when i miss shifted from 3rd to 2nd on the interstate... heard the motor rev up to 9+K and knocked it back in neutral.....
          Please, Leave me some feeedback on my ride ^CLICK ^CLICK ^CLICK
          But Honda guys know EVERYTHING about EVERYTHING! If you don't believe that, then you're just wrong...
            I would decide the transmission after I decided the setup. If you wanna go all motor go with the shorter geared transmission, if you wanna go turbo, go with the longer geared transmission.
            -Keylan-
            My hopes and dreams of a CB7 have been dashed!
              Yeah, that is very true. Longer gearing on a turbo motor allows the it to stay in boost longer.
                so i want to turbo the f22 when the time and money is saved up. what transmission should i get? or should i stay with the a1?
                HIX
