starting to go turbo
    pm Jimy..guy is also going turbo with his cb..
    Yes he's from here
      Yes he's from here
      jimmy cool his he from mn maybe he can give me some pointers i wont be going turbo untill after the mn meet ya can see my car before i get boosted
      86 supra NA (sold)
      91 Supra turbo (drifter)
      99 prelude SH (only when i wanna hit V-attack)
      91 accord (turbo soon dead) "crashed"
      97 civic hatch GSR-T (my babys mama ride) (stolen)
        Originally posted by mn_cb7_boi View Post
        question to all the guys that went the dsm setup dose the newer 94+ turbo manifold fit are cars too with a little mod to the bolt holes
        yeah man, it fits, of course you must redrill the holes yeah.
        i know because i have the old one off my car, in my office, and i put it up to the f22 exhaust gasket.
        "Self Renewed"
          kk thanks thats all i needed to kno cuz i also have the 2g manifold and i wanna put those on in stead of the 1g
          86 supra NA (sold)
            ok another question to the turbo guys whats another method of tuneing your car with out chiping yett i just need it to drive it around town till i can tune it at a shop, i heard that u can run the car with a safc or some type of fuel management
            86 supra NA (sold)
              lisin if you want to go turbo go greddy they make 15 psi stock
                and you can go up with the boost just make sure your trany can hold it and piston and block
                  greddys outta of my pocket range iam not planning to drop 3 grand on that just yett iam just planning to boost low 4-7psi tops i just need something to get my car tuned and running till i can get it fully tuned by a shop
                  86 supra NA (sold)
                    good grab on the turbo supplies
                    you will need to do some fabrication to your 1or2g mani to put on your ct26 turbo, it wont bolt up stock because of flange sizing. Also it is possible to run safc but I wouldnt suggest it. If only to 7 psi. you might be able to manage for a while but I would suggest upgrading as soon as possible. Big 16g is an excellent turbo for your engine, my setup exact f22a4 with the big 16g and aem ecu. The 14b is a little small and could hurt the engine with the excess heat it will put on the motor but if you can find a way to deflect some of the heat you might be able to see around 190-240hp with it, depending on tune. A different style manifold will also divert some of the excess heat away from the motor.
                      great sound good ill just run with the 14b and do some therm wrap and run the turbo for a few months till i get the 16G
                      86 supra NA (sold)
                        you'll still need to run your car hard on a abandon road or on a dyno to set your fuel curves. You wouldn't want to run to lean or way to rich. A little rich wouldn't hurt you either but way rich can cause some issues to your block.
                        Your going to need to run a ecu that can be chipped so you can run a stand alone system. Greddy e-manage is a good system but not too many people uses it.
                        I'd go with a hondata s200 if you just want something that will help you run safely. There is tons of tuners out there that can tune the hondata's. There may also be people who may be selling the old set of hondata such a stage 2 wth boost. There is tons of info on the web about turbo's.
                        I can give you more info if you come to the meet. But I'm no turbo gurru. I have only owned two turbo vehicles. And it was a learning experience.
                          the easiest way, to get rid of the ecu/tuning the ecu.
                          is to swap your injection sytem to carberated.
                          it's not that difficult, using one off the earlier accords.
                          I've seen it done many times,
                          then all you have to do is change the jets and watch your spark plugs.
                          It's not near as effecient but it does work and make lots of power.
                          "Self Renewed"
                            I've always been fascinated by carb'd turbos.
                            It's not all that much more difficult to learn how to tune using Crome or Uberdata, though.
                              k thanks i might just try to pick up a ecu by MRX and take it to RS or DB and get them tuned but yea ill come to the meet and we can talk more
                              86 supra NA (sold)
                                question iam takeing off my AC to make room for my turbo what size belt should i get when i take off the AC
                                86 supra NA (sold)
