ok, as stated in the title my car starts and runs normal when it is first started. idles, accelerates and runs great... until about 20 minutes into a ride then it idles very roughly. I would have to keep my foot on the gas a bit to keep the car from stalling out.
the original engine had a head gasket blown so i had a 5th gen motor swapped in, it was a f22b2 i think. what I've done so far to try and remedy the problem has been: plugs, plug wires, cap, the whole distributor, fuel filter wasn't to long ago, cleaned the egr, iacv, re soldered the main relay.... couldn't fix the problem. a friend told me it may be the fuel pump? i need some input on this, and hopefully it could fix my problem. again the engine runs like normal and idles fine until about 20mins into a drive. Thanks in advance
