buzzing from turn signals
    ok recently when i go to use my turn signals(left or right) all i get is a annoying loud buzzing noise and the signal wont work? the signal lights come on in the gauge cluster but nothing happens from the corner lights, bumper lights, or tail lights? help me out guys?!
    Official CIVICKILLER's members ride thread! http://www.cb7tuner.com/vbb/showthread.php?t=112829
    rock her with the shocker!
    it sound like you have a bad relay somewhere in the system, get the noise to start and look/feel around under the dash for the source
    1990 accord Honda-Challenge, H22 powered
    newer race video,older race videos
    1991 accord parked, parts and back up shell
    1993 accord acquired 6-11-16
      kinda what i was thinkin
        replace your flasher under the dash
          where is it located underneath the dash?
            nvm, i think i know where its at!
              Originally posted by be3p067
              Your blinker fluid is low.
              haha, i better check the muffler bearing while im at it!
                Yes this is true and to fix this you need to replace blinker fluid holder that looks like relay, under steering wheel above fuse box. just find where the noise coming from.
                  interesting but useless fact - i read somewhere that flasher relays are only good for 4,000,000 (4 million) cycles. i guess that translates into ~15 years. not bad.
                  '93 EX-R 5spd
                    Sounds like a bad relay.
                    94' CD5 EX - Best of Both Worlds
                    Support an ICT Meet
                      the turn signals on our cars are controled through the hazard button
                      92ex coupe h22
                      93 240sx with silvia front end (kadet in the works)
                      http://www.cb7tuner.com/vbb/showthre...=1#post1894990
