Timing belt kit recommendations?
    I'm looking for a good compromise of price without losing too much quality and wanted to find some recommendations. 2.2l on a '90.
    Ordering these parts in addition:
    Distributor Cap
    PCV Valve
    Cylinder Head Gasket Set (holy gaskets! stem seals and all)
    distributor rotor
    radiator
    upper and lower radiator hoses
    spark plugs
    spark plug wires
    Currently: 1996 Dodge Caravan (DD), 1990 Honda Accord LX
    Currently pulling the head to fix borked valve(s). Converted to external ign. coil.
    Previously: 1991 Dodge Dakota, 1995 Ford Contour GL, 1992 Mazda Protege DX
    dont skim on price this is your car would u skim on shoes or cloths i mean come on its not that much.
      Best way i can think of to save money on the parts that you can...
      Timing Belt OEM
      Waterpump OEM
      Balance belt OEM
      Balance shaft seal OEM
      Crank seal OEM
      Balance shaft seal retainer OEM
      Cylinder Head Gasket Set OEM
      Valve seals OEM
      Distributor Cap Auto parts store
      PCV Valve Auto parts store
      distributor rotor Auto parts store
      radiator junkyard
      upper and lower radiator hoses Auto parts store
      spark plugs NGK
      spark plug wires NGK
      cheap out on the easier stuff to replace...
      Formerly 91AccordExR33
      11.68 @ 127mph
      417whp/375wtq
      Sold: 8/2016
        Timing Belt OEM
        Waterpump OEM
        Balance belt OEM
        Crank seal OEM
        Valve seals OEM
        radiator junkyard
        spark plugs NGK
        if your wantting to save money delete the balnace shaft belt but deff get OEM cam crank and balance shaft seals and get the balance shaft seal retainer as well.
        water pump oem
        also a good time to check valve adjustments.
        quality work and parts dont come cheap.
        is the motor out of the car? if it is i would go ahead and do rear main seal clutch and oem thorw out bearing as well, if its not out of the car then i would just stick with the timing belt...
        heres a cheap seggestion. when your putting it back, cut out a hole in the lower timing cover so you can slide it over the pulley so you dont have to take the pulley off to get the cover off... i would not leave the cover completely off on the bottom like some people do just because the cv axle inner boot. when it rips it throws axle grease all over the cover.. better for the cover to get it than the timing belt. "cars with intermidite shafts"
        if your taking the head off to re do the head gasket then i would probally look into redoing the pistion rings and possibly new rod main and thrust bearings in the bottom end while you got it all apart
        Please, Leave me some feeedback on my ride ^CLICK ^CLICK ^CLICK
        But Honda guys know EVERYTHING about EVERYTHING! If you don't believe that, then you're just wrong...
          Junkyard Radiator? Good luck with that.
          Get one from ebay, got a brand new oem spec aluminum for 59 bucks.
          wat?
            damn thats nice i paid almost 200 for my full alumi radiator off ebay 2 years ago
              I found this kit awhile back. It sounds like good quality stuff and it comes with everything.
              http://cgi.ebay.com/ebaymotors/Super...6555QQtcZphoto
                not somethin i would get, but he wanted a cheap option lol. Of course there are better places to score....
                11.68 @ 127mph
                417whp/375wtq
                Sold: 8/2016
                  hey man not sure where u are located but in delaware we have a parts store called Berrodin....they sell a complete timing kit...water pump,both belts and both idlers....i think they go for 200 or so list....i think i paid 130 last time i got one...ive used these a lot and they are of the highest quality....i mean oem is always nice but not always necessary....
                  Lost Motion Inc. Repair and Performance Automotive
