Rpm's Jump up and down
    Hey guys something seems wrong with my car. I had my swap for about a year now and my Rpm's are jumping from 1500 to 800. I checked all the vaccum lines and ish but dont know what else is wrong any suggestions would be great thanks.
    If all your vacuum lines are good then it would be a good idea to check out your fitv and iacv.
      tighten down your fitv and clean your iacv. if that doesnt work then you have a vacuum leak. check the diy section on how to do these. SEARCH BUDDY!
      alone in this game . ::My Ride My Way::
        i had the same thing happen to mine(not a swap though) I hosed out the MAP sensor and it fixed the problem right up.
          Check your coolant level.
          Also, you can try a search for "Surging" on the site. Surging is the name for what you are experiencing.
          1992 Prelude S w/swapped H22A
            Thanks for the help guys.
              my f22b did the same thing..I had a bad ecu..XENOCRON ecu fixed it
              MRT H22A - 302whp - N2O
              MRT F22B - 643whp - 529tq @ 30psi
              11.33 @ 131mph @ 27psi
                Check IACV.
                Facebook.
                Xbox Live: Call Of Duty4: Unt0uchable15 --I'm a beast!
                Member Ride
