is it highly recomended to change the suspension bushings? anyone here rolling with stock bushings on a lowered cb?
n00bish suspension question
I gotta change mine, they are all dried out, along with balljoints and endlinks. Next time youre under the car changing your oil, take a look at your bushings. I bet they are all cracked and dried out, just like mine. Bushings are an expendable part, just like brakes and tires, they just last a little longer.
Originally posted by xj1234 View PostThis is true. Only change them if they are causing a problem. Changing your factory swaybar endlink bushings to poly will give you the most noticeable difference as they wear out quickly.
Originally posted by jimy View PostWhen your car starts to wobble. Its time to change the bushings.Originally posted by xj1234 View PostThis is true. Only change them if they are causing a problem. Changing your factory swaybar endlink bushings to poly will give you the most noticeable difference as they wear out quickly.
ESP when it comes to things like tyres, brakes, and suspension.
If a bush is starting to get cracks or splits in it - Change it.
Don't wait untill its broken right through and "The car starts to wobble" Thats just being ignorant from a safety point of view.
My 5.7 LS1 Holden Ute
Originally posted by Skiers Eat Beef View PostWhere can I pick up Energy Suspension bushings?
