H22 oil pump...F22 block
    Can a H22 oil pump fit directly on a F22a block???
    A wise man sees failure as progress...
    Bump
      Bump
        Or is it beneficial to use H22 oil pump gears in a F22 oil pump for better oil pressure...
          Pump number are different most likely wont work, but if you get the two pumps together you might be able to see were they need to be modified to work.
          http://www.hondaautomotiveparts.com/...P-OIL+STRAINER
          Click Me
            is there any benefits of the H22 oil pump compared to the F22 oil pump...
              you can blueprint the f22 oil pimp.
                huh?
