auto trans probs
    auto trans probs
    I recently bought an accord for my girl which also happens to be the first automatic I've bought.. I stay to 5 speeds because I u derstand them better and prefer them. Well here is the problem.. When accelerating it seems that the transmission doesn't want to upshift to the next gear, especially from 3rd to fourth, when in third I simply ease off the accelerator from a steasy throttle and it usually upshifts to fourth. The other problem I'm having is when hitting a turn. Example: cruising doing 45 and let off the gas and hit the brakes to drop down to say 20 before hitting the turn well if I try to give the car gas when goin through the turn it seems that the transmission isn't kicking into a gear or its slipping and the rpms keep climbing while the car proceeds to not accelerate until I exit the turn and stat going straight again where it seems to jump a little bit before finally catching a gear and accelerating. Some help would be appreciated and I hope I explained it so that you understand what's going on.
    Hunter
    it could be the solenoids that control the shifting or it could be something simple as needing a tranny flush and replaced with geniune Honda ATF.
