I'm not sure if this is the right section but here goes. I have 90 se that came with drum brakes on the rear. I plan on doing a rear disc conversion this weekend, the local scrap yard has a few 90-92 CB7's. I kinda know that i neen the full rear suspension complete with trailing arms and all and also the ebrake cable. i want to know where on the car is the proportioning valve located and do i need to get one? The parts that i need for this swap, what years CB7's can i get these off of?
1990 se/exr rear disc conversion
Originally posted by Leung View Postif you truely had a 91 SE, then it should have came with rear discs.
the prop valve is in the engine bay underneath the brake master cylinder against/ near the firewall.
Might be different trim levels up there.
Originally posted by Leung View Postsorry i didn't notice that you're from Canada.
our 91 and 93 SEs down here came with rear discs, which i was trying to pull basically everything you getting also but mine were missing a bunch of parts and it started to rain so i gave up.
Time is money...
The 92-93 EXR (canadian) have the Rear Disc. The EX models DO NOT have disc.
The Canadian EX is a US-LX trim.
As for the prop valve, i have heard of people that didnt use them, and have had no problems.... GL Let us know how it goes.90 Accord EX F22a1 Auto R.I.P.
2011 Mazda 3 Hatch 2.5L GS sport HELLO!
So i went to the local junk yard and got the whole rear assembly, trailing arms, upper control arms, e-brake cables, brake soft lines,disc and calipers. I could not get out the 17mm bolt for the strut so i took the struts as well. I got alll this for $80 which i think is a good deal. The only thing is that i was told to get the 40/40 proportioning valve from a none ABS CB7 with disc brake, but they all had ABS. Unles there is a way around this i will have to use my stock one. Any ideas on what the best way is to remove the siezed 17 mm bolts from the struts?Last edited by sleeper759; 08-09-2008, 02:36 PM.
