Reman. Calipers
    Reman. Calipers
    I currently have the Nissin front calipers but I need to replace them. I will be purchaseing the Akebono calipers from tasauto.com.. when you purchase reman. calipers do you get the bracket and everything? Or will I need to purchase akebono brackets as well.. is there anything else I'll need for the conversion? Thanks
    usually just the caliper.
    it shoud say in the discription. BUT im sure you wouldnt have posted if it did.
    just call when you order. theyll be able too tell you. OR im sure you could email them. but then you have too wait on a response.
    alls you need is the caliper and bracket
      Reman. Calipers
      It depends on the company whom the supplier uses. But most of the time the remanufactured calipers will come with the brackets!!!
      My VIP Inspired Legend:
        Get new pads then.
        They are different pads for each caliper.
        Dont forget to get the calipers powdercoated to protect from rust, and make sure you get new brackets, If you re-use old ones with new calipers, it *may* cause trouble.
        90 Accord EX F22a1 Auto R.I.P.
        2011 Mazda 3 Hatch 2.5L GS sport HELLO!
