What kind of internal upgrades are available for the f22 dohc?? where can you get them?
F22 dohc
depends on what you want from the car. the h23 head is the exact same thing as far as flow goes so its useless as far as an upgrade and the h22 head would be a fairly good up grade if you could find one cheap. but you will have to do some modifications to the head. look at a head gasket for an f22ax and look at one for an h22. you'll see the differences. in my opinion i would just find a set of h23 cams and send them out to delta and get 272 regrinds. i think its like $100-$125 per camshaft, then get up with MRX and get a chipped p06 for about $150-$200 and get it dyno tuned. what all do have done to it now?
all depends on your long term goals. frank motors usually dont last that long so i would do a head swap especially an h22 head. for the price for the mods you can actually get a motor swap. if you are looking for a n/a motor h22. if you wanna go turbo get an h23 or f22b. same hp different torque. with the right turbo you wouldnt really notice the difference. so its up to youDont drive faster than your gaurdian angel can fly
Originally posted by mickey_601 View Postall depends on your long term goals. frank motors usually dont last that long so i would do a head swap especially an h22 head. for the price for the mods you can actually get a motor swap. if you are looking for a n/a motor h22. if you wanna go turbo get an h23 or f22b. same hp different torque. with the right turbo you wouldnt really notice the difference. so its up to you
and to correct myself I WOULD NOT do the h22 head simply because the f22 bottom end is not meant to rev as high as the h22 head and the low compression pistons can not take full advantage of that head. but as I stated above the frank motors dont usually last that long. Only people I know of is lodollar and dep22. someone correct me if I'm wrong.Dont drive faster than your gaurdian angel can fly
