F22 dohc
    F22 dohc
    What kind of internal upgrades are available for the f22 dohc?? where can you get them?
    same as for a f22 sohc on bottom and h23 or f20a on top and you can find them almost anywhere just google it
    Dont drive faster than your gaurdian angel can fly
      ok...if it is the same would it be better to keep the bottom and put a h23 or maybe an h22 head on it?
        depends on what you want from the car. the h23 head is the exact same thing as far as flow goes so its useless as far as an upgrade and the h22 head would be a fairly good up grade if you could find one cheap. but you will have to do some modifications to the head. look at a head gasket for an f22ax and look at one for an h22. you'll see the differences. in my opinion i would just find a set of h23 cams and send them out to delta and get 272 regrinds. i think its like $100-$125 per camshaft, then get up with MRX and get a chipped p06 for about $150-$200 and get it dyno tuned. what all do have done to it now?
        MRT: http://www.cb7tuner.com/vbb/showthread.php?t=95154
          well i got just a stock f22a1 now. im just looking for the best option to swap and im planning on getting the dohc f22 and trying to find out the best way.
            all depends on your long term goals. frank motors usually dont last that long so i would do a head swap especially an h22 head. for the price for the mods you can actually get a motor swap. if you are looking for a n/a motor h22. if you wanna go turbo get an h23 or f22b. same hp different torque. with the right turbo you wouldnt really notice the difference. so its up to you
              he's right, a good mod would be the h22 head, but modding the f22 is fairly cheap. a dsm turbo setup can build some pretty good numbers. but make sure to upgrade to a 16g if possible on the dsm manifold. and i dont recommend much more than 8-10psi.
                the h23 head is actually different from the f22b. the h23 has quench? ont he sides of the chambers. also remember that the bottom end of the f22b is a f22a which is 85mm bore. a h23 bore is 87mm so with that being said, a h23 might have a larger diameter combustion chamber.
                  and to correct myself I WOULD NOT do the h22 head simply because the f22 bottom end is not meant to rev as high as the h22 head and the low compression pistons can not take full advantage of that head. but as I stated above the frank motors dont usually last that long. Only people I know of is lodollar and dep22. someone correct me if I'm wrong.
                    i am planning on getting an f22b and buiding it for a turbo. I was wondering which would be the best way to build as far as internal upgrades.
