F20A7 O2 Sensor testing
    Hey
    I have idle problems with my UK spec '93 Accord Coupé.
    Here are the exact symptoms when the problem started:
    - Warm up fast idle fine.
    - Idle okay BUT
    - Touch the throttle even slightly (i.e. without even really increasing the revs) and the idle dropped to 400 or even stalled. If it didn't stall it hunted a few times back up to 900.
    The car stalled with IACV unplugged so I gave the idle screw two complete turns to bring the idle without IACV up to 450rpm. This fixed the problem for a while but the problem eventually returned. I gave the screw another couple of turns and it got slightly better but only just.
    So it seems like there's way too much fuel for some reason?
    I also have an intermittent code 43 from the ECU.
    I've pulled the O2 sensor and tried testing the voltage output with a blow torch and multimeter - anyone tried this?
    Voltage went quite quickly to .9v then dropped slightly to .8v put dived back to basically zero as soon as I removed the heat.
    Any ideas?
    cheers,
    dod
    1993 Accord Coupé
    1989 RX7 Turbo II
    1989 Charade Turbo
    No one?
    1993 Accord Coupé
    1989 RX7 Turbo II
    1989 Charade Turbo
      Originally posted by doddy View Post
      No one?
      code 43 means fuel supply system which usually leads to the o2 sensor being broken.
