Hello everyone! My name is Cali. I'm new to this site, and I need some help with the timing tensioner pulleys. I searched on the search link but didn't find anything related to the pulleys. While reading the instructions for changing the timing belt on the link. I did everything that needed to be done at a point, until the adjusting nut was really hard to break loose. I kept stripping the bolt while loosing it. I managed to get it loose. But, the adjusting nut was pretty much shot... so i had to remove it to replace it with a new one. Now the pulleys are out of its original position. Does anyone know how to put them back to its original positions? Thanks
Timing tensioners pulleys
Originally posted by ilac_mil View PostHello everyone! My name is Cali. I'm new to this site, and I need some help with the timing tensioner pulleys. I searched on the search link but didn't find anything related to the pulleys. While reading the instructions for changing the timing belt on the link. I did everything that needed to be done at a point, until the adjusting nut was really hard to break loose. I kept stripping the bolt while loosing it. I managed to get it loose. But, the adjusting nut was pretty much shot... so i had to remove it to replace it with a new one. Now the pulleys are out of its original position. Does anyone know how to put them back to its original positions? Thanks
Originally posted by H22artman View Postare we talking geared sprockets or roller bearings?Last edited by ilac_mil; 08-03-2008, 11:01 AM.
I'm assuming you're working on a manual tensioner setup since you have two springs.
Retension both belts by the book. Take the balance belt off and do the timing belt tension, tighten the lock bolt (leave it tight if you want), then do the balancer tension. Don't loosen the adjusting nut any more than necessary when allowing the springs to tension, or the tensioner pulleys can go out of alignment. Make sure you turn the crankshaft over a few times and can bring everything back into alignment at TDC after you think you've got it. The springs set the tension, let them do their job, and Good Luck!
PM me and get it done right!
Originally posted by lucid View PostI'm assuming you're working on a manual tensioner setup since you have two springs.
Retension both belts by the book. Take the balance belt off and do the timing belt tension, tighten the lock bolt (leave it tight if you want), then do the balancer tension. Don't loosen the adjusting nut any more than necessary when allowing the springs to tension, or the tensioner pulleys can go out of alignment. Make sure you turn the crankshaft over a few times and can bring everything back into alignment at TDC after you think you've got it. The springs set the tension, let them do their job, and Good Luck!Last edited by ilac_mil; 08-03-2008, 01:47 PM.
i took that bolt off for some reason when i did mine, i just put it back on tensioned everything acording to my chiltons and havent had problems yet, its been like 3k miles90 accord coupe-f22a4
jdm accord inspire emblem, jdm cb3 sidemarkers, black bumper and amber corner lenses, 92/93 trunk swap with red/clear tails, ebay muffler, sri, p12 ecu, clock from a 95 gs-r(amber diy soon maybe), da teg headrests, almost too low drop on no name springs with aftermarket struts =] (dont hate, im poor!)
r.i.p 91 coupe r.i.p 90 4dr r.i.p 88hondalegend c27a1 5 SP!
i <3 my cb7
www.myspace.com/eryeryerr
I have the whole pulley out. I just don't know if the pulley needs to be in a certain position when i assemble it back on. I mean when you put it on without the adjuster nut on it, it shifts up and down without the spring. But when you put the spring on, When you lift the pulley up, it puts tension on the spring. When you push it down it doesn't put any pressure on the spring. Where should this pulley be at when i put it back together with the adjuster nut tighted and the 10mm bolt next to it?Last edited by ilac_mil; 08-03-2008, 02:08 PM.
Originally posted by Shehzada View PostIs it a good idea to replace these 2 springs when doing a T-belt change?
14516-P0A-000 (Timing Belt Tensioner Spring)
13407-P0A-000 (Balancer Belt Tensioner Spring)
Ok, here's a picture so we can be sure what parts we're talking about.
#22 is the bolt/shaft that the tensioners go on
#21 is the pivot pin that the hole in the right side of the timing tensioner goes on
You will have to push down on the timing tensioner and use the lockbolt (not pictured) to temporarily hold the tensioner out of the way (against the spring) enough to put the timing belt on
To be Honest, I think you should replace the springs.
They are only 3 bucks tops.
The Timing belt jumped 3 teeth because the previous mechanic did not bother to change these springs.
When I pulled out the old ones. They were really stretched.
I don't know if its wear or the mechanic did something to wear them out.
3 bucks a spring is cheap insurance to make sure that everything works right and you don't have to open up the engine again.
All i wanted to know about this is that, I've taken the timing balancer belt pulley out. I just want to know how to position it back where it belongs or does it need to be in a certain position Thats all, But i do have it back on did the original tension (loosen adjusting nut, tighting it, rotated the crank three teeth on the cam, loosen adjusting nut then tighting it deal.) I just hope the belt doesn't jump any teeth when im readyto start it. Also, I moved the bottom crankshaft about a 1/4 inch turn during the timingbelt procedure, my camshaft also moved just a little, am i still safe?Last edited by ilac_mil; 08-13-2008, 06:27 PM.
Spin the crankshaft around a few times, come back to TDC and check all the alignments again. I'm replacing valves in an H22 right now because I didn't double-check things. The balancer belt pulley only goes on one way since it goes over the crankshaft key, but you have to use a long 6mm diameter rod to tell if the rear balance shaft is right. I hope this helps.
