its not running at all now the map sensor is done any idea where i can get a 2 bar map sensor then ill get it tuned any sugestions on wat ecu to use.
Boost falls off after 3psi
sounds like a boost leak to me, not lag.
I'm changing your thread title. It's not very descriptive.
i'm suprised it even idles with 500cc+ injectors and the stock ECU.
Originally posted by deevergote. View PostThat may be why he's saying it isn't running now...
We really need more details regarding the setup to know what's going on... but regardless, this is halfassing to the extreme!2010 Taurus SHO - Livernois Goodies
Originally posted by F22HB View PostThats what ebay claims..
Is the op still around?
If the OP is still around, I hope they're reading this... and not sitting around with a blown engine.
Don't take this the wrong way, but you should have probably sat down and thought this out BEFORE your threw the parts on there.
At the very minumum, you should at least buy a chipped ECU from one of the members here, even if it's just a base map. its better than the STOCK ECU.
Look up a shop in Woodbury Heights, NJ called All About Performance. It's not very close to you, but they're really good... and they know Hondas VERY well.
You NEED to tune the ECU. The stock ECU WILL cause damage. It has absolutely NO idea how to compensate for boost, and it doesn't know how to work larger injectors.
What you should do is return the car to stock until you get an ECU. As I said before (I think), you can get a P06 from a 92-95 Civic LX or DX. Have it modified, chipped, and tuned for YOUR car. A basemap is an easy way to blow your engine... but it will make it driveable to a tuning shop.
What I don't understand is how you managed to install a turbo without knowing that the stock ECU won't work with it... I don't mean to offend, but that's just baffling to me!
Just to make sure... you're not running 87 octane gas, are you? Not that it really matters with things being as messed up as they are at the moment... but that's a no-no for turbo as well.
Take the turbo off. Get the ECU. Put the turbo stuff back on. TOW IT TO A SHOP. Have it tuned.
If you can't do that, you can't afford to have a turbo car.
