Brake Lamp
    Brake Lamp
    My brake lamp is on. All my lights work...what the hellis going on?
    Platano Head Man?!
    My Ride Peeps
    http://www.cb7tuner.com/vbb/showthread.php?t=118338
    since you just changend the taillights, you probaly wired something wrong. CHECK if you wired something wrong.
      Nah it was there before the tailights....anything else?
      Platano Head Man?!
      My Ride Peeps
        Your brake fluid is low.
        Also, it is possible to get an intermittent brake light warning when your center high mount bulb is going bad, but hasn't failed completely yet. I have seen that more than once.
        Also, is it the "brake" lamp in the little car icon, or the same lamp that comes on when you put the emergency brake on?
          put your key upto the spot on your cluster
          It will clear any codes you have allready acquired, If the code comes back, use the diagnostic book from a honda dealer to troubleshoot a solution. Probably something simple. Hondas can be finnicky
            The spot on the cluster doesn't clear ANY codes. You have to use the OBD-I service connector for that. The only thing the spot on your cluster does is reset the "maintenance required" indicator, which is driven off of the odometer and turns yellow every 5,000 or 7,500 miles.
            Also, I would expect that someone of your overwhelming abilities to know that the braking system has nothing to do with ECU codes. They are completely seperate systems.
              brake light and CEL codes are two differnt things.
              I am the "other" white meat.
                I know alot
                like his question was electrical,atleast I think it was. Brake lamp right. Shoot me on the miswritten part about code/maintenance. And no not all things are completely different dude. Obviously you need power to your lights, correct? I hope you know that answer. that is the question. Electrical. get off my nuts.
                  If I am not correct
                  then please ask the question more clearly next time, cuz I assumed that was what you were describing. could be wrong though.
                    Get off your own nuts and stop posting blatantly false information. You are a major drag racer and you are spreading BS about stuff as simple as this? Puhlease.
                    The electrical power flowing through the car has NOTHING to do with the status of his lights. A layman could figure out that the problem isn't in the electricity getting to the lights because ALL THE LIGHTS WORK. Therefore, they must be getting power. Logic prevails yet again.
                    The second clue to the problem is that the brake light has nothing to do with the codes, the ECU, or the check engine light. Even if they AREN'T getting any power.
                    Of course, anyone who knows anything about Hondas, especially if they were building sub 10 second cars, would know that there is a level switch inside the brake master cylinder that triggers the brake light when the fluid drops below a certain level, to warn the driver of a fluid leak, and potential brake failure. The ONLY thing that trigger that light are 1) the parking brake being not being fully disengaged, 2) The brake lights being out or failing (only if it is the brake icon on the little car pictogram), or the fluid level being low.
                    Helm's says it, Haynes says, Chilton's says it, and it is all over internet forums. It isn't exactly unpublished information.
                    Now, you can get off MY nuts, and stop posting incorrect, irrelevant and useless information, or I can make you stop. You buried yourself with all of your stupid little antics in the other threads you have been destroying, and you are now on my bad side, so don't expect any kind of breaks. You are clearly not a racer, because ANY racer with a 14 second car they had built themselves would know this simple stuff and clearly you do not. So, you can either drop it here and now, and tuck your tail between your legs, and face the humiliation you have created for yourself, or you can pipe up again and see just how serious I am.
                    I will give you the choice, and nobody has to know what you choose.
                      you are right
                      I am tired. Good job. I didnt even think about what he was talking about. I apologise. It was worded weird, could be interpreted as his car is perfect too. I needed to look 3 times to even see what he had actually asked. Dont be so harsh though, I even make mistakes especially after all this harsh battling all day everyday. good catch though
                        Good. Now we are headed in the right direction.
                          I hope you are joking"my money is on that he just doesn't have a clue.""I have been talking normal. Maybe my "normal" is too articulate for you to comprehend." you are really all a waste of time. I think you are so articulate you belong in juliart dude.lol.. leave it be or you aint gonna get shit outta me. I know you would like that but once the mods here about you making people who can supply good technical support turn to honda tech they might not worship you as much. So shut up.
                          The mods are all aware of what is going on. And most of us frequent Honda-Tech. It isn't like it is some super secret community or anything.
                          P.S. This statement right here is being interpreted as an insult.
                          Here is a link to the rules, in case you were wondering where they might be.
                          http://www.cb7tuner.com/vbb/showthread.php?t=75019
                          Here are the beginner forum rules which are also well posted. Since this IS in the beginner forums, you are also subject to these rules.
                          http://www.cb7tuner.com/vbb/showthread.php?t=43956
                          We gave you chance after chance after chance to succeed, and you repeatedly were unable to. Anybody with ANY technical knowledge would have answered the simple question about a deck plate, and everytime you were given an opportunity to do so, you went right back to the excuses. This was AFTER allowing 14 pages of your flaming 2point6 about his K24 swap.
                          You clearly don't have the technical knowledge, you clearly don't have the CB7 knowledge, and you clearly aren't able to follow the rules. At this point, I doubt that you even own a car, especially since your age changed from 25 to 28 sometime between last night and this evening. That tells me that you aren't being truthful about that either.
                          I don't know if you came from Honda Tech or not, but the BS that goes on there isn't going to fly here. If you call someone out, you BETTER back it up, because the endless flaming, and pretending that goes on over there isn't going to stand here. If you think your technical knowledge is more useful over there, by all means, go post it over there. I don't care.
                          You are banned for 7 days. That is generous for me as I usually START at 2-3 weeks for this kind of thing, but I am going to give you the benefit of the doubt.
                          If you want to come back and play nice after 1 week, then feel free to do so, although you WILL still follow the Golden Rule whether you like it or not. If you don't want to come back, that is YOUR choice.
                            you will eat that shit too. I now remember why i hated you so much. I will not ever help you with anything, this is true. nothing. you fucking asshole. I will help everyone who wants to learn something if you pm me in a few days. If I am banned well then I will post some at honda tech and let the vultures dive in.
                            Because of this statement you are no longer being given the benefit of the doubt.
                            14 days.
                              Originally posted by 92jdm
                              so uh
                              somthin about a brake lamp?
                              lol... sorry.
