I just installed a set of used eibach sport line with kyb agx shocks, When I installed it, I don't think I put in the bump stop and the damper mounting washer (the one under the nut that holds down the hat). Are those two parts gonna cause problem?
I have the front shock set at 3 out of 4 levels, rear at 6 out of 8 levels. the rear tire has one finger of space while the front has 3 fingers, which give me a little boat look.
Then the typical lowered suspension squeaking noise when suspension travels, remedy to this?
I will thank in advance
