N/a Hp
    N/a Hp
    i read this thread but did all of you had the same results??
    http://www.cb7tuner.com/vbb/showthread.php?t=96024
    how much HP have you squeezed out of you F22xx via N/A? Money Into it?
    I/H/E and so on.......
    Pulling out the basic I/H/E won't give you enough gain.
    Full N/A build is where it's at. Bisimito has over 350+ hp on his F22A
    1996 Honda Civic LX 2009-2012
    2012 Kia Optima LX 2012-2013
      I honestly don't believe in really 'building" the f22xx for NA There are some who still just want to keep it and get a little more hp which is obviously fine but knowing where I've been and want to go I don't feel as though it is worth it.
      I also suggest checking a thread on www.gen5alive for a similar comparo in regards to a "built" F22. Reason I say this is because TSM_PIkachu the site admin, as well as store creator is working directly with Bisimoto to do the build and is intentionally keeping it so that the average person would be able to do the modifications as well as have a direct comparison to go by from stock. It is a work in progress but interesting never theless and will give you something else to look at for benchmarks to reach.
      Personally the money spent on that list would be better spent somewhere else but again, not everyone is shooting for the same goals and may not have the funds to do what they really want right away.
      Either way good luck with what you decide.
        i think it's near 400 hp now..
        Ride: 2002 Lexus IS300
          is anyone in here getting 160-250hp via N/A??
            its easy to get there. if you have the money. personally i wouldnt buy any of Bisi parts. not that they arent good. but im going to spend $400+ a header and crap like that. thats too high. i think he needs to build parts for the average tuner and not just people who want to dump thousands of dollars into their car.
            thats why im not buying brand name stuff. people up here would spend $500+ on a freakin cat-back exhaust. i can go 5min down the street and get the same quality exhaust at the local exhaust shop for $100 with my own muffler.
            if you just get the normall I/H/E, an H23 IM, a tune up, maybe even a bored TB and port matched upper plenum, and a 50hp shot of the gas, you'll in the 200hp range (with out the nitrous, maybe like 150-160hp, 145-150whp).
              $2722.48 and only 152 WHP/127 WTQ??
              Your much better off saving for a engine swap if your looking to gain power.
              For 2722.00 you could buy a H22 w/ tranny and have it installed by a shop.
              Or install it your self and still have some money left over.
                either that or boost the f22a you have and still have money left over for a tune and more performance parts
                theres a guy up here who has a delta regrind, H23 IM and TB, i THINK a chipped p06, I/H/E and he's pushing 150whp. so theres always other ways of making that kind of power with the F. you just have to look around a research. now HondaFan81 did that and if he wanted to, can boost if and be pushing alot of HP for an F22a and wont have to worry about the motor taking a vacation.
                  Oh yea, that too.
                  Turbo or Engine Swap FTW!
                    ^^^ i like your Sig
                    -->751 whp @ 27psi <--...Midnight Tuning <----
                      IF you read through his thread you will see what he was trying to prove. And all this runs on the cheapest gas vs an H22a running premium all the time.
                      2722 wont get a shop to do it for you they charge a bit more. From what I see they yrange from 3500-4000 per swap. It also depends on what you need to replace. I spend about 3500 ish on my swap by replacing most of my engine parts with OEM seals etc etc...Factory engine mounts rape you at 700 for all 4.
                        Like I said, if your looking for more N/A power, do a swap.
                        Yes it will.
                        Buy a engine and tranny from http://www.osakajdmmotors.com or http://www.hmotorsonline.com/ or buy from another local.
                        3500-4000?? HOLY SHIT!
                        I have a local shop that will do the swap for ~750.
                        Or I can do the swap a couple of friends, if I were so inclined.
                          I did mine with a friend and most of my cost was extra parts and miscellaneous wrong items. I prefer to make my engine almost brand new before putting it in the car rather than spending the money later to replace a hard to reach seal for no reason.
                            so if wanted to get some serious HP my best options are to boost f22 or swap h22?? f22 easier to replace, h22 expensive to get and mount in. give me your opinions
                              H22 is direct drop in...unless your doing some sort of auto-manual swap other than that its straightforward.
