Installing front engine mount
    What is the best way to install the front engine mount without removing the radiator for more clearance?
    Upper 17mm bolt was pretty easy to remove but one at the bottom, I am having hard to time to removing it. No room to work on.
    CB7 forever!
    1st car: Frost White 1991 Accord EX sedan.. (Dec. 1999 ~ Jan. 2001) *Sold*
    2nd car: Black Pearl 1993 Accord 10th Anniversary sedan (Feb. 10, 2003 ~ Mar. 8, 2008) *Sold*
    3rd car: Frost White 1992 Accord EX sedan (Jan. 15, 2008 ~ Aug. 12, 2008) *RIP*
    4th car: Seattle Silver 1991 Accord EX coupe 5MT (Aug. 13, 2011 ~ Mar. 19, 2014) *Sold*
    5th car: Black Pearl 1994 Accord LX coupe 5MT (Mar. 1, 2014 ~ )
    take off ur header i had to take my front mount out to put the turbo on and it was easy to get to whit no header
    93 EX COUPE, F22A6 turbo project
    http://www.cb7tuner.com/vbb/showthre...45#post1615845
    96 lexus sc300 DD
    http://www.cb7tuner.com/vbb/showthread.php?t=143563
    back from basic.... off to ait.... CB still being worked on i have mad plans for it .. sorry cant tell its on the hush hush for now but all i can say in somewhere around 500 hp soon to come..
      Do you need to put a jack underneath? I need to replace mine to.
        When I did my motor swap, I just used a wobbly, and a long ass extension, I was able to leave my exhaust manifold on, it took some doing, but I got it.
          just use a gear wrench, you know those ratcheting ones that look like a boxend wrench? I've got a 17 and 19mm one thats awesome.
            That is the trick.
            I did it without removing anything.
            No need to jack it up since the front is not a load bearing mount.
            Gary A.K.A. Carter
            [sig killed by photobucket]
              I have 10, 12, 14mm gear wrench. No 17mm ..
                You need to buy a metric set my friend. CB's love the attention of tools. Get used to it.
                Follow me on IG: @jdm_inspired
                93 'til infinity
                  Thanks for the input!
                  I am going buy 17mm flexible end gear wrench, which is 395mm long.
                  I think that should work.
                    Which Gear Wrench did you use Losiracer2?
                    You plan on getting this one, correct?
                      Originally posted by The G-Man View Post
                      That is the trick.
                      Thank you, kind sir!
                        Yes!
                        Orderd from online shopping $28.50.
                          I got my set at Sears. The brand is Gear Wrench lol. But i got a set of two that has about 8 sizes on it.
                          On one wrench, one side has 8/10 other has 12/13. On the larger Gear Wrench, one side had 16/17, the other has 18/19.
                          I paid about 25 bucks + tax for it when it was on sale. I think they're normally 29.99 + tax.
                          But the cool part is, its got 4 sizes on each wrench. 2 per end...you just flip it over to use ie: either 10 or 12, and the ratcheting mechanism is reversable.
                          Its WELL worth the money. I've used it many times for that front mount alone. And for numerous other things that need tight clearance.
                            17mm gear wrench arrived today..
                            and it took me 5 min to change the front engine mount.
                            With right tool, itt was really easy.
                            Top nut is removeable after taking out the bolt.
                            Bottom nut weld on to the frame.
                            You don't even have to hold the nut while loosing the bolt.
                              Yes!
                              nice
