I had a H22 in my 1st CB. I had singles in every other CB I've owned. I want to do something different. I want to know how you guys feel about the G-series. That's the F block with the H vtec head.....
G Series!!!!
G Series!!!!
I fly by like the coupe grew wings!!!
Speeding!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
My coupe!!!
http://www.cb7tuner.com/vbb/showthread.php?t=152924
Originally posted by Racer_XXXExcuse me miss, YOUR FUPA IS IN THE WAY!!!Tags: None
franks are generally more unreliable than matching engines but if youre willing to take the time and do the research and do it the right way, you should be alright. i know a few members are running that setup pretty successfully with boost. it wont be as fast as an h22 due to the lower compression but its all about what you want in the end.
search around a little bit to find out other members' tries at the G and where they went wrong so you have things to look out for
edit: http://www.cb7tuner.com/vbb/showthread.php?t=110149
check that threadLast edited by jacobuchanan140; 07-18-2008, 01:40 PM.
