idle issues
    idle issues
    So i noticed that when i turn my car on itll go to 1500rpm and stay there until it warms up..i know its not supposed to do this because my car normally goes to about 1000rpm and goes to about 800 when its warmed up..whats the issue here? also my car is running rich because i can smell the exhaust gases when i turn the car off and i get horrible gas mileage (22mpg). what are my options?
    Thanks alot
    Brad
    Originally posted by 93accordexcoupe
    cleanest oem rims ive ever seen
    Members Ride
    i think your idle is normal, my car does the same thing. most cars idle faster when they are started to help them warm up quicker
      x2.
      Mine goes up to around 1500 and as it gets warmer it slowly drops down to around 700-800.
      Member's Page:: Coming Soon
        my car warms up in about a minute here in AZ. Idk if I screwed anything up when doing my headgasket (coolant lines), but it never used to warm up that quick before.
        I recently discovered that I had a slightly sticking slide pin on my pass. rear caliper so you may want to check the slide pins on yours funny as that sounds just to make sure. I was getting about 21mpg city w/ occasional highway and a fresh cyl. head rebuild.
        member's ride thread
        91 Accord SE 176k
          I dont know how to check them, but I'm take off the wheels soon anyway, so I figured I'd just greese up all the moving parts int eh calipers...would that do it?
          ^^click it or ticket^^
            yeah I would just check it....you never know...they just fail sometimes w/ mileage and wear and tear. Just remove your wheels and then remove the caliper (piston part). Then you'll be able to remove the slide pins and regrease them. If they won't slide out easily, then take the caliper bracket off and try your best to take them out.
            I had a hard time removing my rear caliper lower slide pins. For some reason the lower ones froze up instead of the uppers, weird.
            But just go to Autozone and buy that little packet of grease they sell to lubricate brake parts. One packet should be enough for 2 calipers to lube up all the slide pins and plates the pads slide on.
            91 Accord SE 176k
              hmm...my front drivers side wheel just started to make a weird noise when i drive..ill get it all checked out
              Members Ride
                is it a humming? that could be a wheel bearing issue. That also robs gas mileage...causing more friction.
                91 Accord SE 176k
                  its like something is caught in there..it sounds like if you were to rub your finger across a piece of paper..but when i apply the brake it stops
                  Members Ride
                    try adjusting the brake dust shield, that's what's prob. rubbing on the brake rotor. Its that black thing behind the rotor, just bend it so its not touching the rotor anymore.
                    91 Accord SE 176k
                      wow this is gonna sound stupid but did you do the normal checks?air cleaner, fuel injectors,fuel filter, exhaust, catylitic converter? also check for gasket leaks in head, intake mani (gaskets) and exhaust. these can often cause erratic idle and serious loss in gas mileage, also check for flow in pcv valve and all tubes to see if leak,also egr valve, I'd bet you anything yours is filthy,might be wrecked if so you can get one cheap. Hope this helped
                        mine idles at that same rpm i thought there was somethin wrong but if others do that too then maybe not
                        Click Here To Check Out My Ride
                        http://www.cb7tuner.com/vbb/showthread.php?t=137030
                          Mine does the same thing. I'm beginning to think this is a common problem for all.
                            only advice you need
                            buy a haynes manuel, theyre cheap, theyre at every auto parts store in america and they'll teach you a little bit about diagnosing problems with your vehicle. and like I said before check the chapters on the areas I stated on my above post.
                              A 1500RPM initial idle is normal for a cold engine. The FIV steps the idle for a faster warmup and to prevent idle surge when the engine is cold.
                              That comes from a Helm's manual, which is the official OEM manual.
