Valve Lash Adjustment
    Im going to attempt replacing my crank pulley as well as the lower spark plug tube o-rings. is there a special type of valve adjustment screwdriver i need? i c one here on amazon that says:
    Alltrade 648827 10-Millimeter 7-1/2-Inch Jam Nut Valve Adjustment Tool.
    will it do the job?
    you dont need a special tool. what i usually do is leave the feeler guage between the valve and rocker arm and keep measuring as i adjust and finally tighten.
    took me about 30 minutes yesterday.
      ive heard that u need a 'tool' bcuz dont u gotta fuck with the screw as well as the nut?
        well, if u have done it b4, all i need is a feeler gauge then? cuz i saw the 'tool' on amazon, if it makes it easier then, ill buy it, if its not that serious then i wont.
          Did you have any trouble with the screw being stuck to the nut? I remember trying to do mine and the adj. screws were practically welded to the nuts.
          "The fault-finder will find faults even in paradise. Love your life, poor as it is. You may perhaps have some pleasant, thrilling, glorious hours, even in a poorhouse."-Henry David Thoreau
            i havent had any problems with a 100k motor and even my 212k motor. you can try cracking them loose after you run the motor. just pop the valve cover and crack em loose.
              I can easily get the nut loose but then the screw turns with it. They're stuck together.
                which is why i ask about 'the tool'. the tool has a socket to hold the nut and a screwdriver-like object which projects through its shaft and will turn the screw, as the nut is held in place.
                  It will make it easier... but if you just hold a screw driver and tighten the nut w/ a 10 mm you should be fine.
                    Question...
                    What is the clearance for our motors? Int / Ext.
                    Are they all the same for all F22A1 / 4 / 6 ?
                    I just dont want to do mine as I hate fartin around with getting #1 on the power stroke. Is there a posting that covers doing this from start to finish?
                    A
                      A
                      .010 and .012" respectively.
                      i dont care what stroke it is on, i just make sure that im on the back of the camshaft lobe when im checking it. make sure the car is completely cool too.
                        Update:
                        Ok Gotcha... I was hoping it was that simple. I did it to my 12 Valve '85 Prelude but that was a long time ago...lol
                          thanks though, guys...ill order that tool right now...just need some torque wrenches now....
                            http://www.cb7tuner.com/vbb/showthre...lve+adjustment
                            92ex CB7<-SOLD 93ex CB9shiftingshift73C10
                              There a picture of that special tool somewhere. Just search for it. Although you don't really need a special tool for you to do it...
