Aftermarket Cam Gear install
    I want to purchase an AEM Cam Gear the problem is I don't now the procedures to install it. How should I go about this?
    Thanks.
    If you are buying an aftermarket cam gear, you should know how to install it.
    I don't mean it is easy, I mean that you do not need an adjustable cam gear unless your engine is pretty well built up. And if you built up your engine, you will know how to install it.
    I digress...
    Take off the upper timing cover held on by two (2) 10mm bolts. Then you will see the stock cam gear held on by one (1) 12mm bolt. Take a wire tie, and hold the timing belt in place with the stock gear so you don't lose it's place. Unbolt the stock cam gear, slide it off of the cam shaft, make sure you do not lose the key, the slid eon the new cam gear, in the corresponding position to the stock gear. Put in the key, then torque down the 12mm bolt to spec. 28 lb/ft I think. Then slide the timing belt back on.
    ^^click it or ticket^^
      Ok Thanks. I plan On doing alot to the motor so I am just starting with a little at a time.
