sorry for mi English. OK i will buy a 92 accord. the car hasn't being turn on for 3 years should y buy it or not and if i buy it What should y do for maintenance.. ex what should i change to make it be like noting happen... tanks
what to do???
Ok change or check the following:
- Engine Oil (recommended)
- A/T oil
- Brake fluid
- Power steering fluid
- Coolant
- Air filter
- Fuel filter
- Distributor cap & rotor
- Spark plugs & wires
- All belts
- Timing belt check
- Brake pads & rotors check
1996 Honda Civic LX 2009-2012
2012 Kia Optima LX 2012-2013
- A/T oil
- Brake fluid
- Coolant
- Air filter
- Fuel filter
- All belts
- Timing belt check
- Brake pads & rotors checkI old cars
Syndicate
87' Mazda rx7 TII - not stock
90' Honda Accord coupe - stock
- A/T oil
- Brake fluid
- Coolant
- Air filter
- Fuel filter
- All belts
- Timing belt check
-drain old gas out of the fuel tank and refill with fresh gas.
-check all vacuum hoses for cracks or leaks, replace as necessary
I would tow it to be safe.
I have an 86 Accord that was sitting for the majority of 4 years. Because it sat unrunning for so long, it burns a LOT of oil. I'm replacing the engine at only 120,000 miles!
Be prepared to drop another engine in there, or rebuild the one that's there. It may not do what mine did, but it might.
