ok guys, i have a 92 accord EX and it has 250,000 miles on it. it still runs like a champ but I just put $575.00 into the A/C. I gotta replace the motor mounts, timing belt, water pump, front seal, buy a short ram, header, and replace the entire exhaust system. I read today that the ring on the crank that connects the piston rods goes bad on these around 250k too so that would require hella work. I recently had a Lexus SC400 and a BMW 5 series but I sold them to avoid the payments and high ass gas prices but this Accord needs hella work to get it to a nice performing car. My question is......where is the best place to buy a VTEC from Japan? I will need the engine, tranny and computer. I have seen some stuff on line but I don't know if the product will be in good shape by the time it makes it to Vegas from Japan. I'm not Donald Trump but I don't mind paying a little more for high quality if you know what I mean. I just want to hurry up and finish these upgrades so I can have a great car and chill but if I sink alot of money into fixing up the stock engine and the bottom half craps out on me, then I will have wasted ALOT of dough that I could have put toward buying a low mileage VTEC from Japan. Thanks....sorry about rambling!
should I buy a VTEC from Japan?
www.hmotorsonline.com is a good site. They're really reliable and don't try to pull a scam on you. A lot of members here recommend them.
member's ride thread
91 Accord SE 176k
There are lots of places. Look around and see what you want to spend your money on. If you want a engine with transmission or if you want just the long block that helps with costs. Personally I've found a seller on Ebay who also has a web sight for imported engines. I got the F22B non Vtec with tranny for under 1000. of course my tranny needed a complete rebuild (cough *1500* COUGH!).
but here you go.
http://www.japaneseengineimport.com/engines/honda/
one I like is:
http://www.jdmenginedepot.com/jdm_en...6B_CivicType_R
WHA!!! MORE SITES who-E!
http://www.jdmenginescorp.com/engines/honda/
(P.S-That last site you can find engines with LSD transmissions for just a bit more)Been a long time. Still alive...
When I said site I ment this one hmotorsonline.com is where I got my motor great service, price and warranty.
This is what I ment swap section:
http://www.cb7tuner.com/vbb/showthread.php?t=5423Love Built Inc.
Well here's something to think about, If you buy another engine, you're still gonna have to replace the motor mounts, I would recommend replacing the timing belts and water pump, the seal is $5 and is replaced at the same time as the timing belt. The same exhaust bolts up, except the header. Read tho the swaps forum, alot of good info there.
I totally get what your saying but what about the crank issue? I'm gonna be out the cost of getting all the work done. Right now I live in a guard gated condo and the homeowners assoc. is hard on anyone working on cars on site much less major motor tweaks plus it's 112 degrees here right now so I can't do any of the labor which means I gotta shell out the dough to get it done either way.
Originally posted by Losiracer2 View Postwww.hmotorsonline.com is a good site. They're really reliable and don't try to pull a scam on you. A lot of members here recommend them.
As for the crank issue, I have no idea what you're talking about. The ring that connects the crank to the rods? Are you talking about the rod bearings?
