Does anyone else have water coming in their trunk when it rains? My friend's dad who drives a CB7 has it too, but neither of us have figured out where it's coming from and I don't want it to hurt my amp.
Trunk Leak?
it could also be the weatherstripping around the trunk. check to see if they are squashed down flat, or torn. if they are replace. if not spray water on the TRUNK ONLY and then check for leak. if there iswater in your trunk dry it out and rub the seal with vasaline and reapeat process. it quick and easy. i would do that before pulling things apart to check the drains and taillight seals.
Mine leaked , replaced the seals didnt leak for about 8 months now leaks again , I think seals need more , meaning some sort of gasket maker or something with the seals ... Im not sure how im going to do mine but Im telling you Im sick of the damn water I have a nice trunk setup subs Nitrous ect ... no more water for me Im doing something about this .. this week .. LOL
I live in Oregon and I had a problem with this too. I went to the Honda dealership and got some seals for the tailights and haven't had a problem since. I think the seals were around $25. Better do it soon though, I ended up having to replace the wiring harness for my passenger side tailight because so much water had got in.
GaberGaber
I have the water in the spare thing.
I'll notice water dripping from the underside of my car, but the carpet and everything else inside the trunk isnt wet.
I guess its something i should look into cuz after so long all that water could lead to rust.
Originally posted by JarrettIs there a goal you're trying to accomplish besides looking dope as hell?
This has been discussed a number of times. It is almost always leaking from the rear glass molding clips.
http://www.cb7tuner.com/vbb/showthread.php?t=16577
Lexus SC300 1JZ-GTE - garage queen
1991 Honda Accord Ex - daily beats
Originally posted by shern View PostThis has been discussed a number of times. It is almost always leaking from the rear glass molding clips.
But really, it's almost always the tail light gaskets. They are 25 a piece from honda. Expensive, but kept my trunk dry.
