pt6 ecu application for manifold swap
    Does anyone know the difference in the PT6-A51 VS the PT6-A52 vs pt6-a59 ECU's. I am geting ready to do the manifold swap on my F22A1 to the H23 manifold and the PT6 was recommended as the ecu. I just want to make sure I buy the proper ECU to make it run . It is an Automatic.
    Also does anyone know if this ECU will work on a 92 prelude with a f22a1 engine and auto trans. It is currently equipped with an Pt12
    Range Racing #65
    Does Anyone Have An Idea If The Pt12 Ecu Will Work With The F23 Minifold Swap. And Do I Need To Electronically Open The Runners?
    Range Racing #65
      You can have them set to open with vacuum, but it's not ideal. The p12 will not open them. The PT6 is probably the best choice.
        will a pt6 work in the 92 prelude with the f22a1?
        Range Racing #65
          And does it really matter if vacuum opens them if we are usually wide open between 4000-6000
          Range Racing #65
            I can't say for sure how well it'll work with vacuum. However, I would think it'd be fine at WOT.
            As for the PT6, yes, it'll be fine. The ECUs are interchangeable, and will run any F22A motor. However, the PT6 has IAB control, and is optimized for the F22A6 parts. The A6 camshaft would be an upgrade there as well.
            The ONLY difference between the Accord F22A1 and the Prelude F22A1 is the ECU.
              just stick to p12 for f22a1 engines not wrong will happened to your car
              that is a good idea!!
              i feel good cause i beat a 350z~
                Could also use an RPM window switch for the secondary runners and keep the p12 ECU you have.
                Or get the other A6 parts (cam and header) and go for the PT6.
                Opal Metallic Green '92 LX 2dr manual, 181k miles, '94 prelude VTEC wheels for summer (steelies with snow tires for winter), Omni-power struts/springs, and other junk
                  Thanks to everyone for ALL of their help. We are going to get the swap done right away.
                  This forum is awesome.
                  Range Racing #65
